Tagital T9X Screen Replacement
  1. Tagital T9X Screen Replacement, Back Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • With the tablet turned off, remove the two 5mm Phillips head screws from the top of the tablet.
    • These screws are extremely easy to lose. Be sure to store them in a safe place.
  2. Tagital T9X Screen Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a 1 cm wide plastic opening tool to remove the back panel. Go around the entire back panel to ensure safe removal.
    • The power, return, and volume buttons are not firmly secured to the panel; it is likely they will fall off in the process of removing the panel.
  3. Tagital T9X Screen Replacement, Battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a plastic spudger, carefully pry the battery from its position. Ensure that you do not puncture or bend the battery in this process.
    • The only wires for removal are the red and black wires that are soldered into the battery and motherboard.
  4. Tagital T9X Screen Replacement, Screen: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four 2mm Phillips head screws from the motherboard.
  5. Tagital T9X Screen Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Tagital T9X Screen Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Tagital T9X Screen Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Locate the 2 ZIF connectors.
    • Remove both ZIF connectors by lifting the flap on the connectors and carefully removing the ribbons.
  6. Tagital T9X Screen Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the motherboard and battery from the back of the screen.
  7. Tagital T9X Screen Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the spudger, pry the screen from its housing.
    • The display screen is secured by small plastic pieces that snap over the edges. It may be easier to start from the corner of the display screen to detach it from the touchscreen.
Christopher M Shultz
crwdns2935283:001/29/16crwdne2935283:0
208 crwdns2915208:0crwdne2915208:0
University of Kentucky Louisville, Team 1-1, Matravers Spring 2016 crwdns2935289:0University of Kentucky Louisville, Team 1-1, Matravers Spring 2016crwdne2935289:0
LOUISVILLE-MATRAVERS-S16S1G1
crwdns2936753:030crwdne2936753:0 4
crwdns2942667:0crwdne2942667:0 439
