Tagital T7X Screen/ Digitizer Replacement
    1. Tagital T7X Screen/ Digitizer Replacement, Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Tagital T7X Screen/ Digitizer Replacement, Case: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Tagital T7X Screen/ Digitizer Replacement, Case: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Place the Tagital T7X on a sturdy surface.
      • Insert the plastic opening tool into the crack and pry open the tablet. Move the tool along the edge, while continuing to pry up the casing.
    1. Tagital T7X Screen/ Digitizer Replacement, Battery: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Tagital T7X Screen/ Digitizer Replacement, Battery: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Follow the attached wires to the positive and negative connections.
    2. Tagital T7X Screen/ Digitizer Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Tagital T7X Screen/ Digitizer Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Tagital T7X Screen/ Digitizer Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • The soldering iron can destroy components on the motherboard. Only touch the soldering iron to the solder already on the board.
      • Touch the tip of the soldering iron to the solder connecting the negative wire.
      • Pull back on the wire with the iron in place, removing it from the hot solder.
      • The solder will be melted almost instantly. There is no need to hold the iron on the solder for more than a second or two. Visit iFixit's soldering guide for more info.
      • Repeat this step for the positive wire.
    3. Tagital T7X Screen/ Digitizer Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Tagital T7X Screen/ Digitizer Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Tagital T7X Screen/ Digitizer Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Use the nylon spudger to pry the battery from the back of the screen. Work your way around the edges, similar to opening the casing.
      • The adhesive used to hold the battery down is very strong. Don't be afraid to use some force.
    1. Tagital T7X Screen/ Digitizer Replacement, Speaker: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Tagital T7X Screen/ Digitizer Replacement, Speaker: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Tagital T7X Screen/ Digitizer Replacement, Speaker: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Remove the ribbon cable on the top left corner of the mother board.
      • Gently lift the black tape up to see the ribbon cable socket.
    2. Tagital T7X Screen/ Digitizer Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Tagital T7X Screen/ Digitizer Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Tagital T7X Screen/ Digitizer Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Push both side buttons away from the socket by using a spudger.
    3. Tagital T7X Screen/ Digitizer Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Tagital T7X Screen/ Digitizer Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Gently pull the ribbon cable away from the socket.
      • Don't be afraid to use some force for this step.
    4. Tagital T7X Screen/ Digitizer Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Tagital T7X Screen/ Digitizer Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Touch the tip of the soldering iron to the solder connecting the positive (red) wire.
      • Repeat this step for the negative wire.
      • The solder will be melted almost instantly. There is no need to hold the iron on the solder for than a second or two. Visit IFixit's soldering guide for more info.
    5. Tagital T7X Screen/ Digitizer Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Tagital T7X Screen/ Digitizer Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the speaker from the motherboard.
    1. Tagital T7X Screen/ Digitizer Replacement, Camera: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Tagital T7X Screen/ Digitizer Replacement, Camera: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Tagital T7X Screen/ Digitizer Replacement, Camera: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Use a spudger to hold the cameras in place.
      • Gently pull the black tape away using your finger.
    2. Tagital T7X Screen/ Digitizer Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Tagital T7X Screen/ Digitizer Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Tagital T7X Screen/ Digitizer Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Remove the ribbon cable from the motherboard.
      • Use a spudger to lift the two tabs, freeing the ribbon cable from the socket.
    3. Tagital T7X Screen/ Digitizer Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Tagital T7X Screen/ Digitizer Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Tagital T7X Screen/ Digitizer Replacement: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Gently pull the ribbon cable away from the motherboard.
      • Don't be afraid to use some force to pull the ribbon cable.
    1. Tagital T7X Screen/ Digitizer Replacement, Motherboard: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Tagital T7X Screen/ Digitizer Replacement, Motherboard: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Next we will disconnect the digitizer ribbon cable from the motherboard.
      • Using the black spudger, gently push the tabs on each side of the socket to free the ribbon cable.
    2. Tagital T7X Screen/ Digitizer Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Tagital T7X Screen/ Digitizer Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Gently pull on the ribbon cable, separating it from the socket.
    3. Tagital T7X Screen/ Digitizer Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Tagital T7X Screen/ Digitizer Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Tagital T7X Screen/ Digitizer Replacement: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Next, we will unscrew the three PH#0 screws anchoring the motherboard into the case.
      • You will need the Phillips Screw #0 to remove the screws of the motherboard.
      • Using the screwdriver, with the PH#0 attachment, carefully unscrew the screws of the motherboard in order to remove it from the device.
    1. Tagital T7X Screen/ Digitizer Replacement, Screen/ Digitizer: crwdns2935265:016crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Tagital T7X Screen/ Digitizer Replacement, Screen/ Digitizer: crwdns2935265:016crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Tagital T7X Screen/ Digitizer Replacement, Screen/ Digitizer: crwdns2935265:016crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Insert a plastic opening tool where the screen connects with the front face of the case.
      • Use a spudger to keep the screen from falling back into the casing.
      • The screen will slide out once the connection has been nudged on three sides.
Garven Dabady
crwdns2935283:002/10/16crwdne2935283:0
370 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 2-1, Sullivan Spring 2016 crwdns2935289:0USF Tampa, Team 2-1, Sullivan Spring 2016crwdne2935289:0
USFT-SULLIVAN-S16S2G1
crwdns2936753:07crwdne2936753:0 19
crwdns2936753:030crwdne2936753:0 99
crwdns2942667:0crwdne2942667:0 1,138
