Table Lamp Bulb and Wiring Replacement
  1. Table Lamp Bulb and Wiring Replacement, Bulb and Wiring: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Switch off the lamp to ensure no electricity is flowing.
    • Unplug the lamp from the power outlet to prevent the risk of electric shock.
    • Wait a few minutes to allow any remaining electrical charge to dissipate.
  2. Table Lamp Bulb and Wiring Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the screw at the base of the lamp that secures the light fixture to the structure.
    • Use the correct screwdriver/wrench (or if it the screw is loose enough, your hands) to carefully unscrew it while applying steady pressure.
    • Keep the screw in a secure place to avoid losing it during reassembly.
  3. Table Lamp Bulb and Wiring Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Hold the socket (the component that holds the bulb) firmly and check if it is attached with additional screws or clips.
    • Slowly pull the socket out of the fixture while being mindful of the connected wiring.
  4. Table Lamp Bulb and Wiring Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Table Lamp Bulb and Wiring Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Table Lamp Bulb and Wiring Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Grip the bulb securely and rotate it counterclockwise to loosen it from the socket.
    • Once removed, inspect the bulb for any visible damage and set it aside if it needs replacement.
  5. Table Lamp Bulb and Wiring Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Table Lamp Bulb and Wiring Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Table Lamp Bulb and Wiring Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Take off the white cover from bottom to top.
  6. Table Lamp Bulb and Wiring Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Table Lamp Bulb and Wiring Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Cut both of the old wires with wire cutters.
  7. Table Lamp Bulb and Wiring Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Table Lamp Bulb and Wiring Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Take out the new wire and make sure lamp wires correlate to its terminal.
    • Neutral is marked blue, hot is marked red.
  8. Table Lamp Bulb and Wiring Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Thread the wire through the small hole under the lamp.
  9. Table Lamp Bulb and Wiring Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Table Lamp Bulb and Wiring Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Secure the wires to the screws using a Phillips screwdriver.
    • Tighten the screws so that the wires are secured under the screws.
  10. Table Lamp Bulb and Wiring Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips screwdriver to screw the wire between its correlating screw.
    • Blue is neutral, red is hot.
  11. Table Lamp Bulb and Wiring Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Plug the lamp in, and the bulb will light up.
Jeffrey Cong
crwdns2935283:002/19/25crwdne2935283:0
193 crwdns2915208:0crwdne2915208:0
UC Davis, Team 3-3, Andersen Winter 2025 crwdns2935289:0UC Davis, Team 3-3, Andersen Winter 2025crwdne2935289:0
UCD-ANDERSEN-W25S3G3
crwdns2936753:030crwdne2936753:0 33
crwdns2942667:0crwdne2942667:0 217
