In this guide, you will learn how to remove the stand for a Samsung C530 Series 5 LCD. The guide is very simple as there are only four screws to remove from the back of the TV itself
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Place the TV face down on a clean flat surface with the stand hanging over one edge.
Remove the 4 screws securing the stand to the TV.
Holding the TV so it does not slide off the work surface, pull the stand straight out of the TV.
crwdns2935229:023crwdne2935229:0
What model # is this???!
What MODEL is this though ?!
Just got to say that it took me an 1:30 to take it off its sutch a bad design.
thank you so much
George Agius - crwdns2934203:0crwdne2934203:0
Pichar problem
Sid sidharth gamer - crwdns2934203:0crwdne2934203:0
Conviene desarmar la base retirada y volver al televisor la parte separada con sus 4 tornillos con lo que se tapa el agujero que queda en el proceso anterior.
Gracias
mario Baccaglioni - crwdns2934203:0crwdne2934203:0
ποιο μοντέλο είναι η τηλεόραση στην φωτογραφία ;
Michael Gerakianakis - crwdns2934203:0crwdne2934203:0
