TOSHIBA Satellite E45W-C4200X Keyboard Replacement
  1. TOSHIBA Satellite E45W-C4200X Keyboard Replacement, Cooling Fan: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 TOSHIBA Satellite E45W-C4200X Keyboard Replacement, Cooling Fan: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the phillips #1 screwdriver, remove the ten 1 mm screws from the back panel of the device.
  2. TOSHIBA Satellite E45W-C4200X Keyboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 TOSHIBA Satellite E45W-C4200X Keyboard Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use plastic opening tool to separate the back cover from the laptop.
    • Go slowly and be careful as the plastic can crack.
    • It is recommend that you start from a corner and run the tool along the edge.
  3. TOSHIBA Satellite E45W-C4200X Keyboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 TOSHIBA Satellite E45W-C4200X Keyboard Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the four .5 mm screws that secure the heat sink using a Phillips #1 screwdriver.
  4. TOSHIBA Satellite E45W-C4200X Keyboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 TOSHIBA Satellite E45W-C4200X Keyboard Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two 1 mm screws that secure the cooling fan using a Phillips #1 screwdriver.
  5. TOSHIBA Satellite E45W-C4200X Keyboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 TOSHIBA Satellite E45W-C4200X Keyboard Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the fan cord from the harness.
    • Remove the cooling fan and heat sink from the laptop.
  6. TOSHIBA Satellite E45W-C4200X Keyboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 TOSHIBA Satellite E45W-C4200X Keyboard Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 TOSHIBA Satellite E45W-C4200X Keyboard Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Carefully peel off the tape holding the heat sink onto the cooling fan.
    • Peel carefully as the tape goes around all four sides.
    • Remove the cooling fan from the heat sink.
  7. TOSHIBA Satellite E45W-C4200X Keyboard Replacement, Motherboard: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 TOSHIBA Satellite E45W-C4200X Keyboard Replacement, Motherboard: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    Anti-Static Wrist Strap
    $7.95
    • Unplug the connection to the battery.
    • Mark sure you are using the anti-static wrist strap for the duration of this replacement.
  8. TOSHIBA Satellite E45W-C4200X Keyboard Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 TOSHIBA Satellite E45W-C4200X Keyboard Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 TOSHIBA Satellite E45W-C4200X Keyboard Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove all remaining external wire harnesses from the circuit board.
    • It is recommended that you use labels or take pictures of the wires you remove to assist in the re-connection.
  9. TOSHIBA Satellite E45W-C4200X Keyboard Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the three screws from the metal bracket on the left side of the circuit board using a Phillips #1 screwdriver.
    • Remove the bracket.
  10. TOSHIBA Satellite E45W-C4200X Keyboard Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 TOSHIBA Satellite E45W-C4200X Keyboard Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 TOSHIBA Satellite E45W-C4200X Keyboard Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the two screws from the black plastic cover using a Phillips #1 screwdriver.
    • Remove the black plastic cover.
  11. TOSHIBA Satellite E45W-C4200X Keyboard Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 TOSHIBA Satellite E45W-C4200X Keyboard Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a Phillips #1 screwdriver, remove the remaining two screws holding the circuit board in place.
    • Carefully remove the motherboard from the device.
  12. TOSHIBA Satellite E45W-C4200X Keyboard Replacement, Keyboard: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 TOSHIBA Satellite E45W-C4200X Keyboard Replacement, Keyboard: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two 1 mm screws from the black plastic cover using the Phillips #1 screwdriver.
  13. TOSHIBA Satellite E45W-C4200X Keyboard Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 TOSHIBA Satellite E45W-C4200X Keyboard Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the Phillips #00 screwdriver to remove the three 0.5 mm screws from metal bracket.
  14. TOSHIBA Satellite E45W-C4200X Keyboard Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 TOSHIBA Satellite E45W-C4200X Keyboard Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the Phillips #000 screwdriver to remove the 44 (forty four) 0.5 mm screws on the existing silver panel.
  15. TOSHIBA Satellite E45W-C4200X Keyboard Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 TOSHIBA Satellite E45W-C4200X Keyboard Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull up on the black tab that is on the silver panel to remove the keyboard.
Brennen Roomsburg
crwdns2935283:002/20/20crwdne2935283:0
127 crwdns2915208:0crwdne2915208:0
The Citadel Military College of South Carolina, Team S3-G19, Eggleston Spring 2020 crwdns2935289:0The Citadel Military College of South Carolina, Team S3-G19, Eggleston Spring 2020crwdne2935289:0
CMCSC-EGGLESTON-S20S3G19
crwdns2942667:0crwdne2942667:0 681
