TI-84 Plus Silver Edition Backup Battery Replacement
  1. TI-84 Plus Silver Edition Backup Battery Replacement, Main Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 TI-84 Plus Silver Edition Backup Battery Replacement, Main Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 TI-84 Plus Silver Edition Backup Battery Replacement, Main Battery: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Push firmly down on the tab located on the back of the calculator near the center.
    • Pull the tab up, lifting it off of the calculator and exposing the batteries.
  2. TI-84 Plus Silver Edition Backup Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Removing the AAAs and the back up battery will clear the calculator's memory. Make sure you have backed up any important data prior to performing this step.
    • Push the positive (+) side of the batteries to remove them
    Removing these batteries and the back up battery will clear the calculators memory.
    Aaron Rueppel - crwdns2934203:0crwdne2934203:0
  3. TI-84 Plus Silver Edition Backup Battery Replacement, Backup Battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the Phillips #00 Screwdriver, unscrew the 15 mm screw holding the backup battery cover, located above the main battery area.
  4. TI-84 Plus Silver Edition Backup Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Grab the plate and lift gently upward, to remove the backup battery cover.
  5. TI-84 Plus Silver Edition Backup Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 TI-84 Plus Silver Edition Backup Battery Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Wedge the small plastic opening tool under the backup battery in the gap to the left of the backup battery.
    • The backup battery is an SR44SW coin cell battery. You can also replace it with a size 357/303 or LR44 battery.
    • Push gently downward until the backup battery pops out.
crwdns2935229:017crwdne2935229:0
Agustin
crwdns2935283:010/20/13crwdne2935283:0
1.035 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 11-34, Amido Fall 2013 crwdns2935289:0Cal Poly, Team 11-34, Amido Fall 2013crwdne2935289:0
CPSU-AMIDO-F13S11G34
crwdns2947412:09crwdne2947412:0
My son's TI 84 Plus C has a rechargeable battery with a little cord attached to it which is significantly different from the AAA's shown in this Guide!
annualgain - crwdns2934203:0crwdne2934203:0
Because it's a completely different calculator.
Ozan Munsuz -
Muy instructivo e ilustrativo que permite fácilmente la operación de cambio de bacteria.
Andres Guaty - crwdns2934203:0crwdne2934203:0
Do NOT replace the back up battery and the main batteries at the same time! If you do, you will lose all of the calculator’s memory.
Alexander Dombroski-21 - crwdns2934203:0crwdne2934203:0
Too late…….. I had about 13000 bytes of programs
Aaron Rueppel -
The TI-84 calculator backup button battery is a size 303 or SR44SW.
speedyfingers - crwdns2934203:0crwdne2934203:0
this didi’t work i have replaced both back up and main batteries
Michael Rubio - crwdns2934203:0crwdne2934203:0
This little button battery was insanely difficult to remove (and replace). It required me to deform my cheap plastic pry tool. Definitely poor design there from TI.
David P - crwdns2934203:0crwdne2934203:0
If the backup battery is dead and I remove it do I have to replace it before the calculator will turn on?
Taylor Sullivan - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 43
crwdns2936753:030crwdne2936753:0 186
crwdns2942667:0crwdne2942667:0 68,886
