Take off the sliding cover, and flip your calculator to the back side.
Press down on the latch, then remove the battery cover.
Remove the batteries.
You can use the battery cover as a plate to keep the batteries.
Use a Phillips #0 to remove the plate from the back up battery.
Remove the backup battery with either a screwdriver or the spudger.
Use a T6 Torx screwdriver to remove the six screws securing the back cover.
What screwdriver was used in this step. ( not the bit the actual screw. driver
Use a prying tool to get a pick into the side and then move it down until it's open.
crwdns2935229:010crwdne2935229:0
Nice! My calculator wasn't turning on, took it apart and rebent the contacts for the batteries, works great now!
