Take off the sliding cover, and flip your calculator to the back side.
Press down on the latch, then remove the battery cover.
Remove the batteries.
You can use the battery cover as a plate to keep the batteries.
Use a Phillips #0 to remove the plate from the back up battery.
remove the backup battery with either a screwdriver or the spudger.
you can use a t6 or tr6 take out all six marked screws
What screwdriver was used in this step. ( not the bit the actual screw. driver
Use a prying tool to get a pick into the side and then move it down until its open.
crwdns2935229:010crwdne2935229:0
Nice! My calculator wasn't turning on, took it apart and rebent the contacts for the batteries, works great now!
