This guide will aid you in replacing your old or worn out battery. Replacing the battery will also increase usage time and enhance all other functions of the device.
Turn the TDK Life on Record Trek 360 on its side as shown and remove the four 8 mm screws holding the battery cover in place with the T-5 torx screw bit.
Place a metal spudger between the small crease of the battery cover and the device, and apply downward pressure.
Pull down like a lever while continuing to apply downward pressure.
Using a spudger or plastic opening tool, lift the battery from the bottom right and rotate it upwards and toward you.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
To remove the battery, use one hand to pull on the battery wires, use tweezers to pull on the connecting head of the speaker.
Good guide, but what battery fits?
I have opened the hatch but I can’t lift the battery out. My battery seems to be glued in place…. :(
EDIT: I broke several cheap plastic spudgers, but when I finally used a metallic one, the battery pack came right out. Yes, I read that one shouldn’t use a metallic one, but this battery is dead like the dodo anyway.
