Do not blow air into tube!
Remove the four rubber feet of the device using a metal spudger.
Remove the four 9 mm Phillips #0 screws located under the feet of the device.
Remove the four 9 mm Torx #8 screws located on each side of the bottom the device.
Pull the bottom cover of the device towards you.
Remove the four 13 mm Phillips #1 screws.
Use one hand to grip the device from the side of the handle, and use the other hand to grip the side of the device that contains the woofer
Pull apart the compartments by applying force in opposite directions.
Disconnect the seven cables attached to the motherboard.
Remove the four 8 mm Phillips #1 screws.
place your hands on each side of the air vent and then place your index finger on the thin plastic half circle that holds the vent in place.
Pull the plastic half circle towards you.
Put both of your hands inside the tube as shown and push away from you.
crwdns2917034:0crwdne2917034:0
Where can I get a new motherboard?
