TCL Stylus Battery Replacement
crwdns2942287:0crwdne2942287:0This is how to replace the battery on a TCL Stylus 5G.
crwdns2944105:0crwdne2944105:0
Press and hold the Power button for 2 seconds.
Then, select "Power off".
Insert a jimmy tool into the casing to create a gap.
Then, put a plastic pick in the gap and remove the jimmy tool.
Finally, lift up to remove the panel.
Remove the 10 Phillips screws holding the plastic shielding from the motherboard.
Then, grab a pick and put in in the slot show on picture 2.
You should then be able to lift the rest of it off.
With your fingernail, lift up the battery connector.
Unpeel the tape holding the battery.
Pull on the sticker located on the middle of the left side (colored green) of the battery to remove it.
NOTE: The pull tab may have resistance.
crwdns2947821:0crwdne2947821:0
crwdns2947823:0crwdne2947823:0crwdns2947412:05crwdne2947412:0
Lg syluis is a non removeable battery
It's just not easily removable. But every battery in every phone is removable if you know what you're doing. That's why the pictures explain. You come in here getting all worked up but your ignorance really shows. Obviously you don't have the intelligence to attempt this kind of repair, so go crochet me some mittens or something.
Its a non removeable battery phone,unless u control it with a chiness &&^&@@ dumb ass move battery
No removeable
Thanks for the information. At least you do not have to deal with heating the phone in order to loosen adhesive which is common with other phone models. Six steps to get to the battery is way easier than going through over 20 steps to do the same thing.
