This guide will show you how to replace the battery in your T-Mobile Sparq or (Alcatel 606a). This is a fairly straight forward procedure that involves removing the back cover of the phone, removing the old battery and installing a new one.
If you're looking at your phone from the front, feel the upper left hand rounded corner. You'll notice a thin opening between the front of the phone and the back cover.
Flip the phone over (as in the picture) and use a spudger or your finger to gently separate the back cover from the phone.
Once the back cover has been removed you can see a small groove above the center of the battery. The arrow on the battery is pointing to it.
Insert the tip of your finger into the groove and gently lift the battery from the case.
