T-Mobile REVVL Plus Battery Replacement
  1. T-Mobile REVVL Plus Battery Replacement, Removing the back: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 T-Mobile REVVL Plus Battery Replacement, Removing the back: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The back of the phone is held on with a combination of plastic clips and adhesive.
    • The entry point is the speaker grille near the bottom of the phone. Be careful not to insert the opening tool directly downward to avoid damaging the speaker.
    • Insert a plastic opening tool in the hole in the back of the phone as shown to lift the back cover.
    • Insert a guitar pick to keep the plastic cover lifted.
  2. T-Mobile REVVL Plus Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    Halberd Spudger
    $2.99
    • Work a guitar pick or opening tool around the edges of the back panel to disengage all clips.
    • There is adhesive around the edges of the back panel as well as around the camera.
    • The fingerprint sensor is attached to the back panel of the phone. Be careful not to rip the flex cable!
    • Insert the hook of a Halberd spudger into the small opening above the plastic part covering the fingerprint sensor and pry it off while covering it so it doesn't go flying away.
    • Disconnect the fingerprint sensor flex cable with the flat end of a Halberd spudger or an opening pick and set the back panel aside.
  3. T-Mobile REVVL Plus Battery Replacement, Removing the midframe: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 T-Mobile REVVL Plus Battery Replacement, Removing the midframe: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 T-Mobile REVVL Plus Battery Replacement, Removing the midframe: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove 10 black Philips screws (including one covered by a white sticker below the camera lens).
    • Remove 12 silver Philips screws.
    • Gently peel up the bottom half of the metal tape to reveal...
    • Two more black Philips screws to remove.
  4. T-Mobile REVVL Plus Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The midframe is held on by strong plastic clips around the edges of the phone. Insert an opening tool or pick as shown near the SIM card slot
    • Ensure that all screws have been removed, then work your way around the edges of the phone.
    • Clips near the corners are particularly strong.
  5. T-Mobile REVVL Plus Battery Replacement, Remove the battery: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the battery flex cable.
    • The battery is held in by 3 vertical strips of adhesive. Use rubbing alcohol and/or heat to soften the adhesive.
    • If you are replacing the screen, skip this step and remove the battery last.
    About how long is the work or labor on this how much am I looking to pay?
    Any Last - crwdns2934203:0crwdne2934203:0
    How much am I looking to pay for this?
    Depending on the size of the flux capacitor in comparison to the flavor of the 3rd jolly rancher in your specific variety pack, as well as the length of chord in your spare bedrooms walk-in closet, all taken into consideration, I'd assume most likely based on the Kelley blue book value on your first vehicle now, that l once you've calculated all these things up, using a red faced calculator, that I truly have no idea, however that being said, I do wish you and yours, the most absolute best of day, and that your soul smiles many times, and that you, and whomever else, may be reading this, are and always will be......truly blessed! Much Love my brothers & sisters out here!
    Charles -
crwdns2935229:08crwdne2935229:0
Patrick
crwdns2935283:005/14/14crwdne2935283:0
6 734 crwdns2915208:0crwdne2915208:0
crwdns2935297:021crwdne2935297:0
How do I change my charging port on my revel plus Coolpad
Brittney Adams - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 36
crwdns2936753:030crwdne2936753:0 166
crwdns2942667:0crwdne2942667:0 22,087
