Syma S107 Gyro Replacement
  1. Syma S107 Gyro Replacement, Counterweight Bar: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Syma S107 Gyro Replacement, Counterweight Bar: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using tweezers, gently remove the two stabilizing links by pulling straight away from the point of connection.
  2. Syma S107 Gyro Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Syma S107 Gyro Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the counterweight bar by removing the screw.
    • One 10.1mm Phillips #0.
  3. Syma S107 Gyro Replacement, Gyro Carriage: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Syma S107 Gyro Replacement, Gyro Carriage: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the gyro carriage by removing the following screws:
    • Two 5.6mm Phillips #0.
    • When reinstalling these screws make sure to line up one screw with the keyway on the main rotor shaft.
  4. Syma S107 Gyro Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Syma S107 Gyro Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently remove the broken gyro carriage by pulling up.
    • Remove blade assembly by simply sliding it up and off the shaft.
  5. Syma S107 Gyro Replacement, Blade Carriage: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Syma S107 Gyro Replacement, Blade Carriage: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Syma S107 Gyro Replacement, Blade Carriage: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Again using tweezers gently remove the stabilizing links from the blade carriage by pulling straight away from the point of connection.
  6. Syma S107 Gyro Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Syma S107 Gyro Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the blades from the blade carriage by removing the following screws:
    • Two 4.7mm Phillips #0.
  7. Syma S107 Gyro Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Syma S107 Gyro Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the following screws:
    • Two 4.5mm Phillips #0.
    • Make sure to remove any broken plastic pins before reassembling the components.
    • You will have to slide the two halves of the blade carriage over the pins on the gyro carriage first when reassembling.
Christopher Smith
crwdns2935283:010/11/14crwdne2935283:0
305 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 1-31, Donnelly Fall 2014 crwdns2935289:0USF Tampa, Team 1-31, Donnelly Fall 2014crwdne2935289:0
USFT-DONNELLY-F14S1G31
Thank you for this guide! This has fixed the issue and made a 35 year old boy very happy!
Patrick haymer - crwdns2934203:0crwdne2934203:0
Cheers thanks too this page I fixed problem  great ,  Martin
Martin Worboys - crwdns2934203:0crwdne2934203:0
Same here, incidentally where can I get replacement batteries please? Also have a “Picolo” heli with a bad feedback IC , supposedly this part can also be replaced on some units as its a soldered vertical board on the main.
Andre - crwdns2934203:0crwdne2934203:0
Thank you! Took forever to find an answer to my problem! Now very obvious thanks to you. My sanity is restored! HaHa!
CRC 04/04/2021
Chris - crwdns2934203:0crwdne2934203:0
I’m halfway there and grateful for the directions. But I’m not having any luck removing the broken plastic pins from the blade carriage. I’ve tried using a needle but no luck. Did anyone else come up against this?
Adam Leavesley - crwdns2934203:0crwdne2934203:0
Now it flies in an oval pattern wat am I doing wrong?
prober1212 - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 41
crwdns2942667:0crwdne2942667:0 14,770
