Swiffer SweeperVac Battery Replacement (PG3000)
  1. Swiffer SweeperVac Battery Replacement (PG3000), Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Swiffer SweeperVac Battery Replacement (PG3000), Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew seven 17.95 mm screws on the side of the device.
    • Unscrew the 13.87 mm screw.
  2. Swiffer SweeperVac Battery Replacement (PG3000): crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Find the sticker on the back of the device. It may have already been removed.
    • If there is a sticker, peel it back from either half of the device.
  3. Swiffer SweeperVac Battery Replacement (PG3000): crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Swiffer SweeperVac Battery Replacement (PG3000): crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Firmly, but carefully grip each half of the case and split it open.
  4. Swiffer SweeperVac Battery Replacement (PG3000): crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the silver-colored battery cap from the top of the battery.
  5. Swiffer SweeperVac Battery Replacement (PG3000): crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the attached battery from the device and place it on the surface.
    • Remove the second silver-colored battery cap from the bottom of the interior of the device.
  6. Swiffer SweeperVac Battery Replacement (PG3000): crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the spudger, apply pressure to the lock on the black wire attachment.
    • While pressure is being applied to the lock, pull the black wire away from the battery.
  7. Swiffer SweeperVac Battery Replacement (PG3000): crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Swiffer SweeperVac Battery Replacement (PG3000): crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the spudger, apply pressure to the lock on the red wire attachment.
    • While pressure is being applied to the lock, pull the red wire away from the battery.
    • When installing the new battery, you do not need to press down on the locks. Simply plug the wires into the appropriate sockets on the new battery.
crwdns2935229:015crwdne2935229:0
Alexander Boesenberg
crwdns2935283:009/22/14crwdne2935283:0
808 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 10-3, Brown Fall 2014 crwdns2935289:0USF Tampa, Team 10-3, Brown Fall 2014crwdne2935289:0
USFT-BROWN-F14S10G3
crwdns2947412:012crwdne2947412:0
This seems very easy. Will try amd make an update
eli3danimator - crwdns2934203:0crwdne2934203:0
This was helpful but my swiffer vacuum had a plastic chassis for the battery and I had to remove the circuit board as well to route the wires on my replacement battery as they were not is the same places as the factory battery.
lillysilbert - crwdns2934203:0crwdne2934203:0
Where do you purchase the batteries
deniseward640 - crwdns2934203:0crwdne2934203:0
Where do you purchase the batteries?
One place you can get the battery pack as shown is here; https://sweeperbattery.com/. The latest model (easier to install) battery in a case (6 cell - 7.2 volt) is also available from amazon.
Dwight Cooper - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 44
crwdns2936753:030crwdne2936753:0 271
crwdns2942667:0crwdne2942667:0 68,878
