Swann Doorphone Video Intercom Wire Replacement
  1. Swann Doorphone Video Intercom Wire Replacement, Wire: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Swann Doorphone Video Intercom Wire Replacement, Wire: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Swann Doorphone Video Intercom Wire Replacement, Wire: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip the monitor of the Swann Doorphone over so that the underside is facing up.
    • Grip the sides of the black rectangular frame where they extend outwards and pull down.
    • After pulling down, pull the frame towards you to remove it from the monitor.
  2. Swann Doorphone Video Intercom Wire Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Swann Doorphone Video Intercom Wire Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Swann Doorphone Video Intercom Wire Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using the JIS #0 screwdriver, unscrew the 2 mm screw in terminal 1 with the blue wire underneath.
    • Pull the blue wire out from beneath the metal plate.
    • Be careful when removing the screw from terminal 1, the metal plate behind the screw is not connected and may fall off.
  3. Swann Doorphone Video Intercom Wire Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Swann Doorphone Video Intercom Wire Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Swann Doorphone Video Intercom Wire Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip the outdoor camera over so that the underside is facing up.
    • Remove the back cover by grabbing the sides of the camera and pulling towards your body.
  4. Swann Doorphone Video Intercom Wire Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Swann Doorphone Video Intercom Wire Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Swann Doorphone Video Intercom Wire Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • With the back cover of the outdoor camera off, press the first gray square button with blue wire down.
    • While pressing the gray square button, remove the blue wire from the first opening under the button.
    • Be sure to remove the same color wire for the outdoor camera as was used for the indoor video intercom.
    • In this guide, we are using the blue wire in terminal 1 for the audio. As a recommendation; * Use the blue wire in terminal 1 for the audio wire. * Use the brown wire in terminal 2 for the ground wire. * Use the green wire in terminal 3 for the video wire. * Use the black wire in terminal 4 for the power wire.
Emily Stenke
crwdns2935283:002/14/18crwdne2935283:0
555 crwdns2915208:0crwdne2915208:0
USF Tampa, Team S2-G4, Eyestone Spring 2018 crwdns2935289:0USF Tampa, Team S2-G4, Eyestone Spring 2018crwdne2935289:0
USFT-EYESTONE-S18S2G4
crwdns2947412:05crwdne2947412:0
Have found wires what do I do now to fix the problem?
Norman Stuckey - crwdns2934203:0crwdne2934203:0
Not much good telling me which wiresEmily. I need to know what to do next
Emily, Anyone home? Still no answer EMILY where are you???
Is the unit stuffed or can it be repaired
Emily Emily where are you?
Just when i thought you were going to be useful you have disappeared
crwdns2942667:0crwdne2942667:0 2,004
