Swagtron T3 Cover Replacement
crwdns2869540:0crwdne2869540:0: 5,8 mil
0
26
5.752
crwdns2959984:0crwdne2959984:0: 0
crwdns2959956:0crwdne2959956:0
crwdns2955944:0crwdne2955944:0: crwdns2931287:05crwdne2931287:0
crwdns2955970:0crwdne2955970:0: crwdns2937799:0crwdne2937799:0
crwdns2862623:0crwdne2862623:0 crwdns2948751:0crwdne2948751:0
To replace other components in the Swagtron T3, you will need to first remove the outer shell by removing the screws. Make sure to take note of where each type of screw goes to streamline the process of putting it back together. To avoid electric shock, discharge the capacitors using the capacitor discharge tool before making any changes to your Swagtron. Click here to learn how to safely discharge a capacitor.
    1. Swagtron T3 Cover Replacement, Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Swagtron T3 Cover Replacement, Cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Make sure the hoverboard is completely powered off and unplugged from any outlets.
      • Flip the Swagtron so that the footpads are facing the ground.
      • Unscrew the sixteen 9.4 mm Phillips #1 machine screws on the side of the Swagtron that is now facing upwards.
    2. Swagtron T3 Cover Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Swagtron T3 Cover Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Swagtron T3 Cover Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Be careful with the small blue capacitors indicated by the orange box. There are many of these capacitors in the device.
      • Slowly lift the backside cover.
      • Both sides lift up the same way, but the motherboard is under one side and the battery is under the other.
      • Detach the four cables connected to the cover by pinching the connector clips and pulling the cables out:
      • Three cables on the motherboard side.
      • Two red cables with white connectors and one white cable with a white connector.
      • One yellow cable with a black connector on the battery side.
      • After detachment, you should be able to completely remove the backside cover.
Klara Perkins
crwdns2935283:004/10/17crwdne2935283:0
412 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S13-G3, Forte Spring 2017 crwdns2935289:0Cal Poly, Team S13-G3, Forte Spring 2017crwdne2935289:0
CPSU-FORTE-S17S13G3
crwdns2935297:048crwdne2935297:0
crwdns2959996:0crwdne2959996:0 5,752
