Surface Laptop Studio SSD Replacement
  1. Surface Laptop Studio SSD Replacement, Lower Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the rubber cosmetic strip along the outside edge of the back plate with tweezers.
  2. Surface Laptop Studio SSD Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Surface Laptop Studio SSD Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two rubber feet on the lower case with an opening tool.
  3. Surface Laptop Studio SSD Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two screws with a T3 Torx screwdriver.
  4. Surface Laptop Studio SSD Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the seven screws securing the lower case with a T3 Torx screwdriver.
  5. Surface Laptop Studio SSD Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Surface Laptop Studio SSD Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the lower case gently and set it above the device.
    • Take care not to strain the battery cable as you move the lower case.
  6. Surface Laptop Studio SSD Replacement, Surface Laptop Studio Battery Disconnection: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Surface Laptop Studio SSD Replacement, Surface Laptop Studio Battery Disconnection: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the battery cable by lifting the pull tab until it "clicks."
  7. Surface Laptop Studio SSD Replacement, SSD: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • After removing the devices battery, locate the SSD next to the mother board.
  8. Surface Laptop Studio SSD Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the single 3 mm screw that secures the SSD.
  9. Surface Laptop Studio SSD Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide the SSD directly out of its socket.
crwdns2935229:05crwdne2935229:0
Nate Ball
crwdns2935283:002/14/23crwdne2935283:0
735 crwdns2915208:0crwdne2915208:0
Western Carolina University, Team 1-3, Virtue Spring 2023 crwdns2935289:0Western Carolina University, Team 1-3, Virtue Spring 2023crwdne2935289:0
WCU-VIRTUE-S23S1G3
crwdns2947412:05crwdne2947412:0
Is this strip tape or it metal? Is there replacements for it? I habe been trying to find it but I can only find tape as an alternative to this part.
Luis Ruiz - crwdns2934203:0crwdne2934203:0
I tried the SSD upgrade with two different WD products (1TB black and 1TB blue) and with both I had problems: Random blue screens and after some time, computed could not find the SSD anymore. Looks like it has something to do with drive consuming too much power but I am not sure. I am now back on original 256 GB SSD, since I can't find what is causing compatibility issues.
Pohistvo123 - crwdns2934203:0crwdne2934203:0
Can you fit a full sized ssd or only the short ones?
Omega_o7 - crwdns2934203:0crwdne2934203:0
You can fit a full-size (M.2 2280) SSD in the Suface Laptop Studio, but you won't be reusing the metal bracket that is there for the small SDD (2230 size). More info available here: https://dancharblog.wordpress.com/2021/1...
DoktorDread -
crwdns2936753:07crwdne2936753:0 79
crwdns2936753:030crwdne2936753:0 335
crwdns2942667:0crwdne2942667:0 12,463
