Use this guide to replace the lower case on your Microsoft Surface Laptop Studio.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Remove the rubber cosmetic strip along the outside edge of the back plate with tweezers.
Remove the two rubber feet on the lower case with an opening tool.
Remove the two screws with a T3 Torx screwdriver.
Remove the seven screws securing the lower case with a T3 Torx screwdriver.
Lift the lower case gently and set it above the device.
Hi. Is this rubber decorative strip reusable?
Is this strip tape or it metal? Is there replacements for it? I habe been trying to find it but I can only find tape as an alternative to this part.
Luis Ruiz - crwdns2934203:0crwdne2934203:0
It appears to be thin plastic with an aluminum coating on the outside. It's easy to remove by poking into the corner by the hinge with a set of tweezers-- the tweezers will pass right through.
Michael Montalban - crwdns2934203:0crwdne2934203:0
Ok and how do you reattach it when you're done? I mean is it glued on or how does that work?
Rika - crwdns2934203:0crwdne2934203:0
