Surface Laptop Studio Fan Replacement
  1. Surface Laptop Studio Fan Replacement, Lower Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the rubber cosmetic strip along the outside edge of the back plate with tweezers.
    Is this strip tape or it metal? Is there replacements for it? I habe been trying to find it but I can only find tape as an alternative to this part.
    Luis Ruiz - crwdns2934203:0crwdne2934203:0
    It appears to be thin plastic with an aluminum coating on the outside. It's easy to remove by poking into the corner by the hinge with a set of tweezers-- the tweezers will pass right through.
    Michael Montalban - crwdns2934203:0crwdne2934203:0
    Ok and how do you reattach it when you're done? I mean is it glued on or how does that work?
    Rika - crwdns2934203:0crwdne2934203:0
  2. Surface Laptop Studio Fan Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Surface Laptop Studio Fan Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two rubber feet on the lower case with an opening tool.
  3. Surface Laptop Studio Fan Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two screws with a T3 Torx screwdriver.
  4. Surface Laptop Studio Fan Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the seven screws securing the lower case with a T3 Torx screwdriver.
  5. Surface Laptop Studio Fan Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Surface Laptop Studio Fan Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the lower case gently and set it above the device.
    • Take care not to strain the battery cable as you move the lower case.
  6. Surface Laptop Studio Fan Replacement, Surface Laptop Studio Battery Disconnection: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Surface Laptop Studio Fan Replacement, Surface Laptop Studio Battery Disconnection: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the battery cable by lifting the pull tab until it "clicks."
  7. Surface Laptop Studio Fan Replacement, Fan: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Surface Laptop Studio Fan Replacement, Fan: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the screws securing both of the fans with a T3 Torx screwdriver.
  8. Surface Laptop Studio Fan Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip up the ZIF locking flap on each socket.
    • Disconnect the ribbon cables attached to each fan.
  9. Surface Laptop Studio Fan Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Surface Laptop Studio Fan Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the fans up and out.
    Could use some help on what the replacement fan is part number or where to buy.
    Gerald Naekel - crwdns2934203:0crwdne2934203:0
    Same problem here has anyone found a solution yet?
    Nils -
    Kann mir auch jemand sagen wo ich neue lüfter bekomme?
Nate Ball
crwdns2935283:002/14/23crwdne2935283:0
708 crwdns2915208:0crwdne2915208:0
Western Carolina University, Team 1-3, Virtue Spring 2023 crwdns2935289:0Western Carolina University, Team 1-3, Virtue Spring 2023crwdne2935289:0
WCU-VIRTUE-S23S1G3
crwdns2935297:013crwdne2935297:0
crwdns2947412:05crwdne2947412:0
Any idea where to buy the parts?
cameronjpu - crwdns2934203:0crwdne2934203:0
Any luck in getting the fan replacement part?
Carlos Pino Tinetti -
Same question, where I can buy those cover plastic stuff.
Mingyuan Ma - crwdns2934203:0crwdne2934203:0
I am also looking for the fan parts
Mike Van Laningham - crwdns2934203:0crwdne2934203:0
Hi, i am looking also for fan parts. If anybody knows, that would be awesome!
Matthias Bockbreder - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 52
crwdns2936753:030crwdne2936753:0 199
crwdns2942667:0crwdne2942667:0 4,102
