Supersonic Matrix SC-91MID Speakers Replacement
  1. Supersonic Matrix SC-91MID Speakers Replacement, Back cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use an opening tool to separate the back cover of the tablet by wedging the tool into the crease between the back cover and touchscreen.
    • Work your way around the perimeter of the tablet to detach the back cover and remove it carefully so you don't rip any cables attached.
  2. Supersonic Matrix SC-91MID Speakers Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a spudger to carefully disconnect the display ribbons from the motherboard.
  3. Supersonic Matrix SC-91MID Speakers Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To remove the battery, use the spudger to pry the battery up and away from the tablet.
    • You might have some difficulty removing due to glue holding the battery in place.
    • Work your way around the perimeter of the battery with the spudger or opening picks gently so you don't bend or puncture the battery.
  4. Supersonic Matrix SC-91MID Speakers Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Supersonic Matrix SC-91MID Speakers Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to remove the speakers.
    • To remove the motherboard, remove the three screws that hold the board in place with a Phillips screwdriver.
  5. Supersonic Matrix SC-91MID Speakers Replacement, Speakers: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Desolder the four speaker wires connecting the speaker to the motherboard using a soldering station.
    • If you're unfamiliar with soldering or desoldering check out this guide How To Solder and Desolder Connections
    • Be sure to wear protective eye wear. Also, keep in mind that the soldering iron will become extremely hot.
    • The tool in the picture is not required for this step. It is just being used to point out the wires.
Andrew Osborn
crwdns2935283:003/21/17crwdne2935283:0
134 crwdns2915208:0crwdne2915208:0
Texas Tech, Team S46-G4, Bennett Spring 2017 crwdns2935289:0Texas Tech, Team S46-G4, Bennett Spring 2017crwdne2935289:0
TTU-BENNETT-S17S46G4
crwdns2942667:0crwdne2942667:0 300
