In this guide, you will remove the back cover of the Supersonic Matrix SC-91MID to access the internal hardware.
Use an opening tool to separate the back cover of the tablet by wedging the tool into the crease between the back cover and touchscreen.
Work your way around the perimeter of the tablet to detach the back cover and remove it carefully so you don't rip any cables attached.
Use a spudger to carefully disconnect the display ribbons from the motherboard.
To remove the battery, use the spudger to pry the battery up and away from the tablet.
Use a spudger to remove the speakers.
To remove the motherboard, remove the three screws that hold the board in place with a Phillips screwdriver.
