Supercycle SC1800 Tire Replacement
    1. Supercycle SC1800 Tire Replacement, Tire: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Deflate the tire by pressing the valve stem in.
      • If it's difficult to press the stem in with your hands, use a plastic wedge tool.
    2. Supercycle SC1800 Tire Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Once the tire is deflated, press the beading inside until it is removed from the rim.
      • If you need to replace your rim, do it now.
    3. Supercycle SC1800 Tire Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Slide the plastic wedge tool under the beading of the tire, and pull it outwards.
      • The tool is not required, but it makes the job easier.
      • Once the tire is removed from the rim on one side, do the same to other side.
      • Make sure not to puncture the tire tube, as you will need that for the new tire.
    4. Supercycle SC1800 Tire Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Supercycle SC1800 Tire Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Pull out the tire tube from the tire and transfer it into the new tire.
      • Make sure the valve is facing towards the center as shown in the second picture.
      • If you must replace your tire tube, do it now.
    5. Supercycle SC1800 Tire Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Once the tube is in place, use a little bit of force to get the beading into the rim, making sure the valve goes through the designated hole in the rim.
      • If it starts getting difficult to push the beading with your hands, use the plastic wedge tool to finish.
      • It is important for the valve to correctly line with the valve hole first. Otherwise, you risk damaging the tire tube.
    6. Supercycle SC1800 Tire Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Do the same to both sides of the beading. You will need to use the plastic tool for the other side.
    7. Supercycle SC1800 Tire Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Re-inflate the tire.
      • It may be difficult to re-inflate due to the folds in the deflated tire tube. Be patient!
Firuz Khandakar
crwdns2935283:009/19/20crwdne2935283:0
219 crwdns2915208:0crwdne2915208:0
York University, Team S2-G7, Melo-Thaiss Fall 2020 crwdns2935289:0York University, Team S2-G7, Melo-Thaiss Fall 2020crwdne2935289:0
YORK-MELO-THAISS-F20S2G7
crwdns2936753:07crwdne2936753:0 18
crwdns2936753:030crwdne2936753:0 78
crwdns2942667:0crwdne2942667:0 1,878
