SuperTooth Buddy Battery replacement
  1. SuperTooth Buddy Battery replacement, Rechargeable batteries: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully lift off the glued on cover.
  2. SuperTooth Buddy Battery replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two screws on the right.
    • There is also a small screw to the left of the green button
  3. SuperTooth Buddy Battery replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • There are also two screws on the back that need to be removed
  4. SuperTooth Buddy Battery replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Be careful when lifting off the cover so as not to damage the two thin speaker cables.
    • Carefully remove the two screws holding the circuit board in place.
    • The battery is located under the circuit board
  5. SuperTooth Buddy Battery replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Order a replacement battery online.
    • Li-ION 3.7V 650mAh 2.41 Wh
    • Make sure that the new battery has the same dimensions as the old one. (In this case it was approx. 50mm x 30mm x 4mm.
    Ce modèle est souvent vendu sous la référence 043048 (en fait, la taille de l'accu : 4x30x48mm !).
    Jean Luc - crwdns2934203:0crwdne2934203:0
crwdns2934873:0crwdne2934873:0
de en
100%
crwdns2934883:0oldturkey03crwdne2934883:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
markus1980wien
crwdns2935283:009/27/15crwdne2935283:0
143 crwdns2915208:0crwdne2915208:0
Ottime istruzioni per lo smontaggio. Grazie. Fino ad ora non ho trovato la batteria sostitutiva su internet. Spero di trovarla.
Eva Verlicchi - crwdns2934203:0crwdne2934203:0
Si può sostituire con una simile, che si trova su Ebay o su Aliexpress, il modello e: ***Batteria a litio 600mAh 3.7 V ricaricabile misura 503040 per dispositivi elettronici. Il Link: https://www.ebay.it/itm/175641031768 oppure: https://it.aliexpress.com/item/322148476...
Claus Col - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 61
crwdns2942667:0crwdne2942667:0 4,125
