In this guide you will need to remove the back cover of the device and then locate the microphone. Using a soldering iron, you will remove the preexisting microphone and replace it.
Because this task requires the use of a soldering iron, prior experience with soldering/desoldering will be beneficial.
Wedge the plastic opening tool between the back cover of the device and the front panel.
You will hear a snapping sound as the cover is separated from the body of the device.
Slide the opening tool along the seam between the front panel and the back cover to un-clip the remaining connections around the device.
Again, you will hear a snapping sound as the cover is separated from the body of the device.
Lift the back cover from the body of the device to expose the internal components.
Remove the microphone from its compartment.
Use the soldering iron to remove the wires connected to the microphone.
