SuperSonic Matrix Mid SC-999 LCD Replacement
crwdns2869540:0crwdne2869540:0: 1.5K
2
19
93
1,527
crwdns2955950:0crwdne2955950:0: 4
crwdns2960004:03crwdne2960004:0, crwdns2960006:01crwdne2960006:0
crwdns2959984:0crwdne2959984:0: 4
crwdns2959974:04crwdne2959974:0
crwdns2955944:0crwdne2955944:0: 15 - 30 crwdns2931279:0crwdne2931279:0
In this guide you will remove the back cover of the device and partially remove the motherboard. Disconnect the screen from the motherboard using a soldering iron and replace it with a new screen.
Because this task requires the use of a soldering iron, prior experience with soldering/desoldering will be beneficial.
    1. SuperSonic Matrix Mid SC-999 LCD Replacement, Back Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Wedge the plastic opening tool between the back cover of the device and the front panel.
      • You will hear a snapping sound as the cover is separated from the body of the device.
    2. SuperSonic Matrix Mid SC-999 LCD Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Slide the opening tool along the seam between the front panel and the back cover to un-clip the remaining connections around the device.
      • Again, you will hear a snapping sound as the cover is separated from the body of the device.
    3. SuperSonic Matrix Mid SC-999 LCD Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 SuperSonic Matrix Mid SC-999 LCD Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Lift the back cover from the body of the device to expose the internal components.
    1. SuperSonic Matrix Mid SC-999 LCD Replacement, Battery: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 SuperSonic Matrix Mid SC-999 LCD Replacement, Battery: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 SuperSonic Matrix Mid SC-999 LCD Replacement, Battery: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Remove the Battery
      • The battery is secured to the back panel with tape and glue.
      • Peel back the tape around the battery and discard it.
      • Tear through the adhesive holding the battery by using the spudger tool.
    2. SuperSonic Matrix Mid SC-999 LCD Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 SuperSonic Matrix Mid SC-999 LCD Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 SuperSonic Matrix Mid SC-999 LCD Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Desolder the 2 Battery Wires
      • The Battery has two wires connected to the motherboard (one black and one red).
      • If you're unfamiliar with soldering or desoldering check out this guide.
      • Be sure to wear protective eye wear. The soldering iron will become extremely hot and a potential danger, so make sure you are aware of your surroundings.
    1. SuperSonic Matrix Mid SC-999 LCD Replacement, Speaker: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the Speakers
      • Use the tweezers to remove the speakers from their compartments.
    2. SuperSonic Matrix Mid SC-999 LCD Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 SuperSonic Matrix Mid SC-999 LCD Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Desolder the 4 Speaker Wires
      • These wires connect the speakers to the motherboard. They are the thinnest wires.
      • Be sure to wear protective eye wear. Also, keep in mind that the soldering iron will become extremely hot.
    1. SuperSonic Matrix Mid SC-999 LCD Replacement, Microphone: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the microphone from its compartment.
      • The microphone is located toward the bottom left corner of the device (assuming the speakers are located on the right side of you).
    2. SuperSonic Matrix Mid SC-999 LCD Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 SuperSonic Matrix Mid SC-999 LCD Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use the soldering iron to remove the wires connected to the microphone.
      • If you're unfamiliar with soldering or desoldering, check out this guide.
    1. SuperSonic Matrix Mid SC-999 LCD Replacement, FM Antenna: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 SuperSonic Matrix Mid SC-999 LCD Replacement, FM Antenna: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use a soldering iron to desolder the region circled in red.
      • Be sure to wear protective eye wear. The soldering iron will become extremely hot and a potential danger, so be aware of your surroundings.
    2. SuperSonic Matrix Mid SC-999 LCD Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 SuperSonic Matrix Mid SC-999 LCD Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Desolder the FM antenna from the motherboard.
    1. SuperSonic Matrix Mid SC-999 LCD Replacement, Motherboard: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 SuperSonic Matrix Mid SC-999 LCD Replacement, Motherboard: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the large ribbon cable from the socket that attaches it to the motherboard.
      • Pull down on the dark grey sliders located on both sides of the ribbon cable to release it.
    2. SuperSonic Matrix Mid SC-999 LCD Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 SuperSonic Matrix Mid SC-999 LCD Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the small ribbon cable from the socket that attaches it to the motherboard.
      • Flip the dark grey latch to release the ribbon cable from the motherboard.
    3. SuperSonic Matrix Mid SC-999 LCD Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 SuperSonic Matrix Mid SC-999 LCD Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 SuperSonic Matrix Mid SC-999 LCD Replacement: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Remove the four Phillips #00 screws attaching the motherboard to the device.
    1. SuperSonic Matrix Mid SC-999 LCD Replacement, LCD: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 SuperSonic Matrix Mid SC-999 LCD Replacement, LCD: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 SuperSonic Matrix Mid SC-999 LCD Replacement, LCD: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Ensure that the motherboard and all other items are off before continuing.
      • Separate the screen and back housing by gently pulling on it.
Harris Dagha
crwdns2935283:003/26/15crwdne2935283:0
866 crwdns2915208:0crwdne2915208:0
Dr Shaverz boyz crwdns2935289:0Dr Shaverz boyzcrwdne2935289:0
Community
crwdns2935297:084crwdne2935297:0
what is the part number & where can I get a replacement screen for the SC-8809
impaired27 - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:07crwdne2936753:0 19
crwdns2936753:030crwdne2936753:0 93
crwdns2959996:0crwdne2959996:0 1,527
