crwdns2959928:0crwdne2959928:0 ↓This guide will have you remove the upper case using a gamebit screwdriver and then in order to reveal the ribbon to the system from the controller port you will have to remove the reset button. This process will require only the gamebit.
Remove the six screws located on the underside of the system using the Gamebit 4.5mm screwdriver.
Carefully flip the unit back over.
Locate the seam. Lift and separate the upper half of the case from the lower half of the case.
Lift the right side of the eject lever out of the housing.
Pull the metal bar out through the right side of the eject lever.
Lift the controller ports out of the housing, this should be done without much force. Take note of the location of the ribbon cable connection.
Carefully remove the ribbon cable from its port.
crwdns2935229:018crwdne2935229:0
I did a complete teardown of my 26 year old super Nintendo because I had to fix the AV jack. the hardest part was the de soldering. however upon putting it back together I could get the games to play, however it was in black and white…or even a grayish hue…and the controllers didn't work. shortly after the ribbon connecting the controller input to the system snapped on one end. do you think this was the issue, and where do I find a new one? Thanks.
Keith Goetting - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
This isn’t complete. How about taking the face plate off?
Daniel Powers - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Find don’t look like screws they look like rivets
Steve Pitcher - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
