Use this guide to replace a broken or damaged hand strap.
Place the lamp LED side down on a clean workspace.
Remove the screws holding the casing together using a Phillips #1 Screwdriver.
Gently pull the two halves of the lamp apart.
Remove both ends of the strap from the orange casing by pulling up.
Insert the ends of the new strap into the strap housing on both sides of the orange component.
