Summer LookOut Duo Motherboard and Display Replacement
  1. Summer LookOut Duo Motherboard and Display Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Summer LookOut Duo Motherboard and Display Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Summer LookOut Duo Motherboard and Display Replacement, Battery: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip the device over so the back is facing up.
    • Remove the 9 mm screw using a Phillips #1 screwdriver.
    • Lift the battery panel away from the device.
  2. Summer LookOut Duo Motherboard and Display Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Summer LookOut Duo Motherboard and Display Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Summer LookOut Duo Motherboard and Display Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip the handheld monitor over and let the battery fall out into your hand.
    • Using angled tweezers, gently remove the plastic wire coupling from the side of the open battery compartment.
    • If the coupling struggles to release, with a loose but firm grip, slightly wiggle the plastic wire coupling back and forth until it releases.
    • Remove the battery from the device.
  3. Summer LookOut Duo Motherboard and Display Replacement, Motherboard and Display: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Summer LookOut Duo Motherboard and Display Replacement, Motherboard and Display: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Summer LookOut Duo Motherboard and Display Replacement, Motherboard and Display: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using the Phillips #00 screwdriver, remove the four 7mm screws from each corner on the back of the handheld monitor.
    • Remove the casing from the back of the handheld monitor.
    • A nylon spudger may be helpful to pry the case open.
    • Using the angled tweezers, gently remove the plastic wire coupling connecting the speaker to the motherboard.
    • The power button may come loose as the case is being removed.
  4. Summer LookOut Duo Motherboard and Display Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Summer LookOut Duo Motherboard and Display Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the motherboard and monitor display together and set aside.
Adrianna Piedra
crwdns2935283:002/25/25crwdne2935283:0
85 crwdns2915208:0crwdne2915208:0
Idaho State University, Team 1-4, Watkins Spring 2025 crwdns2935289:0Idaho State University, Team 1-4, Watkins Spring 2025crwdne2935289:0
ISU-WATKINS-S25S1G4
crwdns2936753:030crwdne2936753:0 2
crwdns2942667:0crwdne2942667:0 88
