Summer LookOut Duo Camera Lens Replacement
  1. Summer LookOut Duo Camera Lens Replacement, Camera Lens: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Summer LookOut Duo Camera Lens Replacement, Camera Lens: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the plastic wall mount attached to the base of the stand.
    • Remove the four 9 mm screws on the back four corners of the camera using a Phillips #00 screwdriver.
    • If needed, gently bend the antenna of the camera towards you to access the screw in the bottom left corner.
  2. Summer LookOut Duo Camera Lens Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Summer LookOut Duo Camera Lens Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Summer LookOut Duo Camera Lens Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently remove the front casing.
    • The motherboard will go with the front casing, so don't pull too hard or else the wires connected to the speaker might break.
    • The back of the motherboard should already be facing up.
    • Remove the two 5 mm screws near the upper center on the back of the motherboard using a Phillips #00 screwdriver.
    • The old camera lens will fall off after the screws are removed.
    • Replace the new lens.
Jordyn Looney
crwdns2935283:002/25/25crwdne2935283:0
425 crwdns2915208:0crwdne2915208:0
Idaho State University, Team 1-4, Watkins Spring 2025 crwdns2935289:0Idaho State University, Team 1-4, Watkins Spring 2025crwdne2935289:0
ISU-WATKINS-S25S1G4
crwdns2942667:0crwdne2942667:0 73
