The GameDAC control wheel is the component that controls the dial of the GameDAC. This electrical component is called a potentiometer. When replacing the potentiometer, one should be careful of wired connections on the circuit board. Follow this guide to safely replace the potentiometer.
Remove the plastic cover using the iFixit opening tool to pry the cover open.
Insert opening picks to keep the cover open as you work your way around the GameDAC.
Pop the cover off.
Remove the control wheel from the GameDAC by pulling on the knob.
Remove the five 6mm screws using the Phillips #0 driver head.
Hold the sides of the GameDAC and pull apart.
Remove the three 4mm screws from the circuit board using the Phillips #0 driver head.
Desolder the seven potentiometer pins from the board to remove the button.
crwdns2935229:05crwdne2935229:0
Hi there,
do you know what type of potentiometer is needed?
Greetings
Chris
I would like to know too. Cause it failed for me as well!!
Can I replace the Oled Screen with 2,42 inch arduino oled display that also have 24pin flex?
