The SteelSeries Arctis Pro headband is a way to secure the headphones around the user's head. This headband is attached to the inside of the headphones and latched onto the headlining of the device using the re-attachable hook-and-loop strap.
Correct headband adjustment is necessary for all users. Without the headband, the headphones will not fit properly on the user's head. Be sure to not be too aggressive in fixing the headband, gentle pulling is all that is needed.
Undo the velcro strap on top of the headset.
Pull the velcro strap out of the headband through the left side slot.
Completely remove the headband strap.
Repeat steps in reverse order for reassembly.
