SteelSeries Arctis 7 2019 Edition Wireless CharMix Dial Potentiometer Replacement
    • Pad is held on by a loop around the outside
    • Grabbing one side of the pad and pulling on it should release it
    • 3x size 0 philips screw hold the right ear speaker in place
    • No screws are hidden under the labels
  1. SteelSeries Arctis 7 2019 Edition Wireless CharMix Dial Potentiometer Replacement, Unscrew the Right Ear PCB: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • 3x size 0 screws hold the Right Ear PCB in place
    • Pull the PCB out by pulling up and away from the headphones
    • The ChatMix Knob may catch on the housing and require a bit of wiggling to get it out
    • Be careful to not break the speaker and connection wires
    • 1x size 0 philips screw holds the existing ChatMix potentiometer Knob
    • Remove the screw and knob. They can be thrown out since we will not need them
  2. SteelSeries Arctis 7 2019 Edition Wireless CharMix Dial Potentiometer Replacement, Remove the existing potentiometer: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the existing potentiometer by cutting each pin on the top side of the PCB (The side with all of the components)
    • You can try to de-solder each pin with a solder sucker or solder braid but I did not have success with this
    • Be careful to not de-solder any of the other components or damage the PCB traces
    • It is ok to leave solder inside of the PCB holes
  3. SteelSeries Arctis 7 2019 Edition Wireless CharMix Dial Potentiometer Replacement, Cut off pins of new potentiometer that are not used: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The far left, far right, and middle pins are what we want to keep
    • The middle left and middle right pins should be cut off
    • The ground pins on the case can optionally be cut to prevent any snagging
  4. SteelSeries Arctis 7 2019 Edition Wireless CharMix Dial Potentiometer Replacement, Solder new potentiometer in the place of the old one: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • This is the hardest step
    • The placement of the holes on the PCB and the potentiometer will not allow for the potentiometer to fall into the PCB holes
    • Due to the different pin placements, the left and right pins should be on top of the left/right holes while the middle pin will be on the back edge of the middle hole
    • Be careful of the angle of the potentiometer. It should be close to parallel with the PCB
    • It is easiest to solder the left and right pins first
  5. SteelSeries Arctis 7 2019 Edition Wireless CharMix Dial Potentiometer Replacement, Solder a length of wire between the middle pin and the back right hole: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The old potentiometer had a unconventional pinout which requires us to connect these two pins
    • Be careful that the wire does not touch other pins
  6. SteelSeries Arctis 7 2019 Edition Wireless CharMix Dial Potentiometer Replacement, Turn on the headset and test that the fix works in SteelSeries GG: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Check that the SteelSeries GG ChatMix bar moves left and right as you turn the potentiometer
    • Be careful to not twist the potentiometer too hard as it could break the solder joints
    • If you're not seeing the ChatMix bar move, restart SteelSeries GG before checking your solder joints
  7. SteelSeries Arctis 7 2019 Edition Wireless CharMix Dial Potentiometer Replacement, Add hot glue in-between the potentiometer and the PCB: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 SteelSeries Arctis 7 2019 Edition Wireless CharMix Dial Potentiometer Replacement, Add hot glue in-between the potentiometer and the PCB: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • This removes stress from the solder joints
    • Be careful to only put hot glue on the back of the metal part of the potentiometer so that it can still spin freely
    • Too much hot glue can prevent the PCB from fitting in the housing. If you place too much, remove it with a knife until the PCB fits
    • Wait for the hot glue to cool before testing the potentiometer in SteelSeries GG. Make sure the solder joints have held
  8. SteelSeries Arctis 7 2019 Edition Wireless CharMix Dial Potentiometer Replacement, Put the headphone back together: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 SteelSeries Arctis 7 2019 Edition Wireless CharMix Dial Potentiometer Replacement, Put the headphone back together: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Be careful when putting the PCB back in that you don't force the potentiometer
    • 3 size 0 Philips screws for the PCB
    • 3 size 0 Philips screws for the Speaker
    • (Optional) Add a small dab of hot glue on the outside of the wheel of the potentiometer when the ChatMix is in the middle to know when the wheel is in the middle
Alec Probst
crwdns2935283:009/21/25crwdne2935283:0
1 crwdns2915208:0crwdne2915208:0
crwdns2942667:0crwdne2942667:0 30
