Starbucks Barista Pump Replacement
  1. Starbucks Barista Pump Replacement, Pump: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Starbucks Barista Pump Replacement, Pump: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Starbucks Barista Pump Replacement, Pump: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • First remove all six screws on the back panel.
    • Remove the back panel, then set it aside.
    • Remove the two screws holding the bottom panel in place.
    • Remove the bottom panel, then set it aside.
  2. Starbucks Barista Pump Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Starbucks Barista Pump Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Starbucks Barista Pump Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the drip tray out, then set it aside.
    • Turn the brew unit clockwise to unscrew.
    • Pull the tube that goes into water reservoir out.
    • Slide the water reservoir out through the front of the barista to remove it.
    • Remove the top tray from the backside.
  3. Starbucks Barista Pump Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Starbucks Barista Pump Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Starbucks Barista Pump Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use an adjustable wrench to unscrew the connection tube between the pump and the boiler.
    • Pull off both tubes connecting on each side of the pump.
    • Remove the 3 electrical connectors from the pump.
    I could not remove the teflon tube from the brass T/OPV.
    See my comment in step 4.
    Gary Naka - crwdns2934203:0crwdne2934203:0
  4. Starbucks Barista Pump Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Starbucks Barista Pump Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Starbucks Barista Pump Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unscrew the two mounting bolts.
    • Remove the pump unit from the Barista.
    • Pull off the yellow end of the pump and unscrew T-shaped end.
    • See the links section of the device page for where to purchase a new pump.
    I went to a link with a picture of the exact pump and model number. What came was a label free pump which is not and exact replacement. There is an o-ring which makes the seal between the tee and the pump so order a new one while you’re at it. The new pump is lacking the o-ring retention groove/recess in the tip of the pump’s brass output where the tee screws in. Since this is flat, the o-ring pinches out and sprays a fine stream out of the joint between the brass tee and the pump output stem. I will be calling them in the morning.
    Model EA Type EAX5
    https://www.amazon.com/gp/product/B00UCH...
    macg - crwdns2934203:0crwdne2934203:0
    As someone else said, for Step 2, I could not remove the teflon tube to the boiler from the brass T/OPV.
    I used his method of unscrewing the pump from the brass T, divider/OPV.
    You first have to unscrew the mounting bolts so that you can rotate the pump.
    I did not have a wrench narrow enough to fit onto the flats on the brass end of the pump. So I gripped the brass end of the pump with a slip-joint plier. It was kinda difficult, having to rotate the pump, but came out fine.
    Same in reverse, rotate the pump, then used the slip-joint to turn the brass end of the pump onto the T/OPV.
    When you screw the mounting bolts back in. The nuts may have fallen down onto the "top tray" in step 2.
    If it fell off, you can reach in from the front to hold the nuts while you screw in the mounting bolts.
    That is why you had to remove the upper plate.
crwdns2935229:016crwdne2935229:0
Alex
crwdns2935283:001/28/11crwdne2935283:0
514 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 4-42, Regan Winter 2011 crwdns2935289:0Cal Poly, Team 4-42, Regan Winter 2011crwdne2935289:0
CPSU-REGAN-W11S4G42
crwdns2947412:022crwdne2947412:0
What is meant by "See the links section of the device page for where to purchase a new pump"? Which device page on which website? Are you not able to just post the link? Which type/model of pump is required?
nick - crwdns2934203:0crwdne2934203:0
My son and I successfully replaced the pump, but it didn't go quite as easily as I'd thought. We could not get the hose that connects the boiler to the pump off. Thankfully, my clever son realized we could turn the portion of the pump that screws into the t-end to get the old pump off and new one on.....tricky, but doable. The new pump is a bit noisier than the last, but she pulls beautiful shots. Thanks so much for this guide!
Bananaslug - crwdns2934203:0crwdne2934203:0
I put in a new pump and it still doesn’t work. I hear it him but can’t get it to pull water. I’ve tried the water in the line thing. How is the best way to prime it? Maybe that’s it?
wendy.tracy007 -
Wendy
Open the steam valve, so there is no back pressure inside the boiler preventing the pump from pulling water.
Gary Naka -
Thanks for this tip.
I had the same problem, could not get the tefflon tube out of the brass T/OPV.
Rotated the pump off the T/OPV.
Gary Naka -
Does anyone know the purpose of the hose that goes toward the back? not the one to the boiler but the other one that goes backward and down from the t-connector? it doesn't seem to be moving any water but the unit seems to work fine.
Michael2020 - crwdns2934203:0crwdne2934203:0
That's a return line I believe. So if there is water left it can drain back to the reservoir.
Chris Slater -
I think it is the overpressure return hose.
The brass T on the output of the pump is the over pressure valve (OPV). When the pressure hits a certain level, the valve opens to prevent the pressure from going above that level. The water leaves the OPV, enters that hose and goes to the water tank.
Gary Naka -
That is the one I bought.
Perfect fit, and seems to work fine.
Gary Naka -
I was given a 10 year ols (approx.) Saeco Barista. It seems very loud when pumping.
I looked under the cover. everything looks new. A little bit of small debris in the corners, probably coffee.
Is the loud pump noise an indication of a worn pump or pump part? I don't think it's vibration. I think y=the pump mounts are intact.
Thanks
Ed
Lionel - crwdns2934203:0crwdne2934203:0
I have the same question. I received mine secondhand as well, and I have no experience with a new one to compare to. It seems to work, but I wonder if it's working well or just limping along. I think mine is ok just going by youtube videos: https://youtu.be/aBYmRHK9BJg and https://youtu.be/ju2GEvlE0hg
Harvey -
It is a vibratory pump, it will make noise.
If you have something on or touching the machine, the vibration from the pump could also be vibrating that making the noise louder.
Gary Naka -
My Saeco Starbucks Barista machine still sounds like the pump is working, but no water is drawn up into the pump. I've tried priming the pump per the original instructions which tell me to open the steam wand while running the pump, but that does no good. And I've taken off the back for a look and everything appears to be properly connected, and, as I said, the pump sounds the same as always.
I assume this means the pump is shot, but I want to ask you all if that's the problem.
joe - crwdns2934203:0crwdne2934203:0
Try removing the filter and pushing water into the line with a turkey baster or similar. Or remove the back, hold the line towards the ceiling higher than the pump to allow air to escape and gravity to help. Tap the line and pump to make sure all air is out of the line. There still might be some inside the pump. The pump does not like to be dry.
Harvey -
Hopefully someone still looks at this page :) A friend of a friend was getting rid of this machine, and I accepted the donation. At first try, the pump wasn't pumping any water in. So I started full tear down of the machine and through couple stumbles and my own interest, took apart the portion of the pump that the water goes through. To my surprise, the inside was full of rust (not mineral). Furthermore, it seems that a lot of the components that comes in contact with the water is just steel (not stainless steel). Is it standard that these pump are made from steel component that are prone to rust, considering that the water for consumption flows right through them?
Thanks, Vasily
Vasily Romanov - crwdns2934203:0crwdne2934203:0
I’ve got a Starbucks Barista purchased in 2004, and it still works . I have found that descaling is a big issue as the machine gets older. Also cleaning the power head from time to time can help with flow issues. Disassembling the power head requires some mechanical skill; that is, you have to have a work environment to keep the parts from scattering, you have to pay attention to how the parts are assembled (take pictures if you need to), and REALLY careful not to lose the springs inside. Once its apart, clean all the coffee residue and oil out that you can, with the exception of stained parts. Reassemble and run a shot. If its still having water flow problems, try descaling, and if that doesn’t solve the problem, you will need to replace the pump.
mike davis -
hi I have this Barista machine & found it works intermitantly with quite a noise, presumably from the pump.
Has anyone had similar issues, & solution
Rob ( Surrey UK)
Rob Mucklow - crwdns2934203:0crwdne2934203:0
If I can hear the pump running but it will never prime even if I force prime it do I still need to replace the motor or just some O rings ??
qw.rick - crwdns2934203:0crwdne2934203:0
I installed a new pump. I hear it hum and some steam comes from the wand but no water is being pulled up. How do I prime it?
wendy.tracy007 - crwdns2934203:0crwdne2934203:0
I sure hope this page is still active. I LOVE my machine and I wish they would make again.
My issue is that when I open the steam wand (for water or steam), water also pulls from the porta filter. (Porta filter will pull on its own without the steam wand). I’ve removed the back but not sure what to look at. Thanks for any help
roxheller - crwdns2934203:0crwdne2934203:0
A little leak is OK, a lot is not.
There is a valve under the boiler. If the valve is worn or the spring is weak, it WILL leak.
1 - Turn the machine upside down, LOT easier than working with your head down looking up.
2 - Remove the shower screen. Careful to not strip the screw head.
3 - The valve is behind the bushing that the shower screen screws into.
4 - Unscrew the bushing. If the machine has not been serviced in a long time, that bushing may be HARD to remove. Mine was. Be VERY careful, the bushing is made of brass (a soft metal), and if you strip the notches on the bushing, you may never get the bushing out. You NEED a tool that will FIT the notches properly, so that you do not strip/round the notches.
5 - The spring and valve are under the bushing.
The spring and valve are available from Steffanos and other places.
Gary Naka -
crwdns2936753:07crwdne2936753:0 19
crwdns2936753:030crwdne2936753:0 74
crwdns2942667:0crwdne2942667:0 37,476
