Staples 34462 Electric Pencil Sharpener Gears Replacement
  1. Staples 34462 Electric Pencil Sharpener Gears Replacement, Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull out the shavings tray from the pencil sharpener.
    • Beware of loose pencil shavings falling on your workspace.
  2. Staples 34462 Electric Pencil Sharpener Gears Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the pencil sharpener on its side.
  3. Staples 34462 Electric Pencil Sharpener Gears Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a Phillips00 screwdriver, remove the two front 11.6mm screws.
    • Using the plastic opening tool, remove the back plastic feet.
    • After removing the back plastic feet, using a Phillips 00 screwdriver, remove the two back 11.6mm screws.
    • The hole is deeper than you may think. It may take some time to get the screwdriver to click in.
  4. Staples 34462 Electric Pencil Sharpener Gears Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully pull apart the bottom panel from the top panel.
    • Be careful not to pull too forcefully as the panels are connected by wires.
    • Beware of pencil shavings falling out onto your workspace.
  5. Staples 34462 Electric Pencil Sharpener Gears Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a Phillips00 screwdriver, remove two 8.9mm flat edge screws from the top section of the top panel.
  6. Staples 34462 Electric Pencil Sharpener Gears Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a Phillips00 screwdriver, remove two 10.3mm screws from the middle section of the top panel.
  7. Staples 34462 Electric Pencil Sharpener Gears Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully pull the cover from the top panel and set it aside.
  8. Staples 34462 Electric Pencil Sharpener Gears Replacement, Gears: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a Philips 00 screwdriver, remove the six 9.87mm screws securing the gear housing.
  9. Staples 34462 Electric Pencil Sharpener Gears Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully pull apart the gear housing's panels.
    • The gears are lubricated by petroleum jelly.
  10. Staples 34462 Electric Pencil Sharpener Gears Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently pry the first gear out of the gear housing with a spudger.
    • To ease reassembly, note the orientation of the gear as you pry it free.
  11. Staples 34462 Electric Pencil Sharpener Gears Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently pry the second gear out of the gear housing with a spudger.
    • To ease reassembly, note the orientation of the gear before you pry it free.
  12. Staples 34462 Electric Pencil Sharpener Gears Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently pry the third gear out of the housing with a spudger.
Brian Eliason
crwdns2935283:010/27/14crwdne2935283:0
379 crwdns2915208:0crwdne2915208:0
Eastern Washington University, Team 1-5, Carnegie Fall 2014 crwdns2935289:0Eastern Washington University, Team 1-5, Carnegie Fall 2014crwdne2935289:0
EWU-CARNEGIE-F14S1G5
crwdns2931471:07crwdne2931471:0
crwdns2935297:011crwdne2935297:0
What about gears? Where do you get them? Mine just needs the gear from step 12 replaced.
krzynka - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 3,660
