If your sharpener is making a loud grinding noise or the electric motor is running but the cutter is not rotating, then follow these steps to replace the gears in your Staples 34462 Electric Pencil Sharpener.
Pull out the shavings tray from the pencil sharpener.
Turn the pencil sharpener on its side.
Using a Phillips00 screwdriver, remove the two front 11.6mm screws.
Using the plastic opening tool, remove the back plastic feet.
After removing the back plastic feet, using a Phillips 00 screwdriver, remove the two back 11.6mm screws.
Carefully pull apart the bottom panel from the top panel.
Using a Phillips00 screwdriver, remove two 8.9mm flat edge screws from the top section of the top panel.
Using a Phillips00 screwdriver, remove two 10.3mm screws from the middle section of the top panel.
Carefully pull the cover from the top panel and set it aside.
Using a Philips 00 screwdriver, remove the six 9.87mm screws securing the gear housing.
Carefully pull apart the gear housing's panels.
Gently pry the first gear out of the gear housing with a spudger.
Gently pry the second gear out of the gear housing with a spudger.
Gently pry the third gear out of the housing with a spudger.
What about gears? Where do you get them? Mine just needs the gear from step 12 replaced.
