Stapler Spring Replacement
Lauren McCabe
crwdns2944107:0crwdnd2944107:0Lauren McCabecrwdnd2944107:0crwdnd2944107:0crwdnd2944107:03crwdnd2944107:0crwdne2944107:0
crwdns2944111:0Dzi 4, 2025crwdne2944111:0
10 - 15 crwdns2931279:0crwdne2931279:0
crwdns2937799:0crwdne2937799:0
crwdns2942287:0crwdne2942287:0
If your stapler isn’t stapling, then there’s a good chance the spring is damaged. This guide's purpose is to assist users in replacing the stapler spring.
If you don’t replace the spring yourself, you’ll either have a broken stapler cluttering up your work space or will end up buying a new stapler altogether.
Before using this guide, check to see if the spring itself is damaged. Another possibility of a stapler not working is a staple jam. Be careful when handling the stapler, since it’s possible to staple yourself. We recommend that you empty the staples beforehand.
crwdns2944105:0crwdne2944105:0
  1. Stapler Spring Replacement, Spring: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Stapler Spring Replacement, Spring: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Open the stapler by gripping the handle to access the spring.
  2. Stapler Spring Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pry open the hook found on the pusher using the tweezers.
    • Hold the handle firmly to prevent the stapler from snapping back.
  3. Stapler Spring Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unhook the end of the spring from the pusher.
    • Pinch the spring firmly between your fingers to keep it from snapping back.
  4. Stapler Spring Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Stapler Spring Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unhook the other end of the spring from the inside of the handle.
    • The spring should be unthreaded from the holes on the handle's metal part.
  5. Stapler Spring Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Stapler Spring Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Press down on the metal part inside the handle with your thumbs until it will not go down anymore.
  6. Stapler Spring Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Stapler Spring Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Push the hammer, the rectangular piece, up and away from the metal part.
  7. Stapler Spring Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Release the metal part inside the handle so it comes away from the hammer.
    • Keep hold of the metal part to keep it from snapping closed.
    A side picture would be even better here, so the user could see the process more in detail.
    Penny - crwdns2934203:0crwdne2934203:0
    Este resorte que se ve, en que parte va?? Se salio y no se donde. Gracias
    Jose Luis Spadafora - crwdns2934203:0crwdne2934203:0
  8. Stapler Spring Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Hook one end of the new spring onto the pusher's hook.
  9. Stapler Spring Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Clamp the pusher's hook closed using your thumb.
  10. Stapler Spring Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Thread the other end of the new spring through the top rectangular hole toward the back.
  11. Stapler Spring Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Thread the new spring through the bottom hole, bringing the end of spring toward you.
    • The spring should create a loop when done threading.
  12. Stapler Spring Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Stapler Spring Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Hook the new spring to the hook on the inside of the handle's metal part.
  13. Stapler Spring Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Stapler Spring Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Press the metal part down with your thumbs until it aligns with the hammer's hole.
  14. Stapler Spring Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Stapler Spring Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Reattach the hammer back onto the metal part.
  15. Stapler Spring Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Stapler Spring Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Close the handle until it clicks back into place.
    • Be careful not to staple your fingers when closing the stapler.
    What is the slide mount thing that you slide into that little square hole to push the stapler forward? What is that thing called? I had somebody use my electric staple gun and that thing is missing. My other second question is are they universal are they all the same size
    Maria Maria - crwdns2934203:0crwdne2934203:0
crwdns2935229:012crwdne2935229:0
crwdns2947821:0crwdne2947821:0
crwdns2947823:0crwdne2947823:0
Lauren McCabe
crwdns2935283:001/16/20crwdne2935283:0
349 crwdns2915208:0crwdne2915208:0
University of North Texas, Team S1-G13, Raign Spring 2020 crwdns2935289:0University of North Texas, Team S1-G13, Raign Spring 2020crwdne2935289:0
UNT-RAIGN-S20S1G13
crwdns2947412:013crwdne2947412:0
Just what I needed. Thank you! Super clear
Daniela Labra - crwdns2934203:0crwdne2934203:0
Can I replace the black rubber piece that goes on my swingling desk top stapler 70 sheet it came off and my dog chewed it up.
Edith Corkell - crwdns2934203:0crwdne2934203:0
fron this sale ski o donde venden los repuestos de esta engrapadora en Venezuela gran caracas
Romulo -
Ihr Artikel war sehr leicht zu verstehen und ich habe es geschafft, vielen Dank gacha life!
Lily Collins - crwdns2934203:0crwdne2934203:0
Where do I obtain a replacement spring for this stapler?
John Drake - crwdns2934203:0crwdne2934203:0
Thank you for this guide, just the ticket!
Chris Painter - crwdns2934203:0crwdne2934203:0
What size spring is used for yhe pusher and where can it be purchased?
MM ERICKSON - crwdns2934203:0crwdne2934203:0
At the top of the guide, click on the link at Parts.
Toon Konings - crwdns2934203:0crwdne2934203:0
The link to the spring from ebay does not show any springs. I like the guide but I have been doing a lot of searching, but can't find a stapler spring.
Barrie Thesen - crwdns2934203:0crwdne2934203:0
The Ebay link for getting a new spring no longer provides any inventory of springs. I have searched a lot for stapler springs and haven't been able to find any.
I love ifixit because of guides like these. Something as simple as how to reattach my spring that came off. I knew where it connected but could not figure out how to thread it through the holes. Thank you!!
Charles Westbrooks - crwdns2934203:0crwdne2934203:0
my hammer of the stapler broke,can you help me?/
ganester - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 147
crwdns2936753:07crwdne2936753:0 1,270
crwdns2936753:030crwdne2936753:0 5,248
crwdns2942667:0crwdne2942667:0 239,195
