Squier Strat Guitar Tuner Replacement
  1. Squier Strat Guitar Tuner Replacement, Tuner: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Squier Strat Guitar Tuner Replacement, Tuner: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Squier Strat Guitar Tuner Replacement, Tuner: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Loosen the string for the tuner you are replacing until there is a lot of slack in the string.
    • This should take roughly 10-20 counter-clockwise rotations.
  2. Squier Strat Guitar Tuner Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Squier Strat Guitar Tuner Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use wire cutters or sturdy scissors to cut the string around the midpoint, being mindful of your eyes.
    • For thinner strings scissors will work, however for thicker strings wire cutters should be used.
    • Be careful when cutting the string. If there is too much tension, there is a possibility the string can snap back and can potentially hit you or those around you in the eye. To avoid this, make sure there is a great amount of slack in the string such that after being cut it will be limp.
  3. Squier Strat Guitar Tuner Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Squier Strat Guitar Tuner Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Squier Strat Guitar Tuner Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unwind the string from the tower of the tuner.
  4. Squier Strat Guitar Tuner Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Squier Strat Guitar Tuner Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Squier Strat Guitar Tuner Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a 10 mm hex-wrench to remove the nut of the tuning tower.
    • Remove the tower, washer, and hex nut.
  5. Squier Strat Guitar Tuner Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Squier Strat Guitar Tuner Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Squier Strat Guitar Tuner Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a small (1-2mm tip) Phillips screwdriver, remove the screw securing the tuner to the guitar's headstock.
    • Remove the tuner from the headstock and set it aside.
    • You may want to keep the tuner parts and screw if you wish to reuse the tuner in another guitar, or to save it as a potential backup!
  6. Squier Strat Guitar Tuner Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Squier Strat Guitar Tuner Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a wet paper towel, or similar material, wipe down the surface where the replacement tuner will be.
    • This step is optional, although ensuring the surface is clean of dust and debris will ensure the tuner remains fixed.
  7. Squier Strat Guitar Tuner Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Squier Strat Guitar Tuner Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Squier Strat Guitar Tuner Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the replacement tuners body into the tuner-hole.
    • Ensure the screw hole lines up with the screw-hole on the headstock.
    • Use the small Phillips head screwdriver to tighten the screw until the tuner is secure.
  8. Squier Strat Guitar Tuner Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Squier Strat Guitar Tuner Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Squier Strat Guitar Tuner Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • On the other side of the headstock, put the new tuners washer and tower on the tuner column.
    • Place the nut on top of the washer and tighten to finger tightness.
  9. Squier Strat Guitar Tuner Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Squier Strat Guitar Tuner Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Squier Strat Guitar Tuner Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a 10mm hex wrench to tighten the tuner nut.
Once you have tightened the replacement tuners nut, the guitar is ready to restring. Congratulations, you have successfully replaced a Fender Squier Stratocaster tuner!
Shan
crwdns2935283:001/19/25crwdne2935283:0
194 crwdns2915208:0crwdne2915208:0
York University, Team 1-6, Woodhouse Winter 2025 crwdns2935289:0York University, Team 1-6, Woodhouse Winter 2025crwdne2935289:0
YORK-WOODHOUSE-W25S1G6
crwdns2936753:030crwdne2936753:0 8
crwdns2942667:0crwdne2942667:0 99
