Sprout Channel Cubby Speaker Replacement
  1. Sprout Channel Cubby Speaker Replacement, Dissasemble the device: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sprout Channel Cubby Speaker Replacement, Dissasemble the device: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use an opening tool to push in and release sixteen small plastic clips around the edge of the case. As the clips are released, gradually pry the case apart.
    • It is easiest to start on the corners.
    I'm not sure what's wrong with ours. The color started fading and the picture looked strange. If I pressed the cubby firmly together it would work for a little while. Now I can't get that to work either. Could it just be a loose connection?
    thisnotbiznas - crwdns2934203:0crwdne2934203:0
    Check the connection for the LCD at the motherboard. Lift up the latch to release the cable, remove and reinstall the cable, and then close the latch again.
    Stephen Martinez -
    Where do I find the LCD connector? My screen is very dim but works.
    tnsimons - crwdns2934203:0crwdne2934203:0
  2. Sprout Channel Cubby Speaker Replacement, Speaker: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sprout Channel Cubby Speaker Replacement, Speaker: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • While using the spatula, slowly get under the top part of the speaker. Then slowly move down the speaker to detach it from the device (there is a small amount of adhesive).
  3. Sprout Channel Cubby Speaker Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sprout Channel Cubby Speaker Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove black tape.
    • Disconnect the red and black wires which are soldered to the device. Make sure to not remove the wires that connect to the battery.
    • Replace the speaker.
    • Follow the steps in reverse order (be sure to solder the wires correctly) to install it.
jasen biggins
crwdns2935283:008/26/15crwdne2935283:0
741 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 14-101, Meier Fall 2015 crwdns2935289:0USF Tampa, Team 14-101, Meier Fall 2015crwdne2935289:0
USFT-MEIER-F15S14G101
Jasen, where can I purchase the replacement speaker for the Sprout?
william mulligan - crwdns2934203:0crwdne2934203:0
There is no way that I would want to take apart a new tablet to replaceor repair the speakers. Why not install it correctly the first time? Appears to be an ongoing issue.
Edreia Jones - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 1,169
