Sprout Channel Cubby Digitizer Replacement
  1. Sprout Channel Cubby Digitizer Replacement, Dissasemble the device: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sprout Channel Cubby Digitizer Replacement, Dissasemble the device: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use an opening tool to push in and release sixteen small plastic clips around the edge of the case. As the clips are released, gradually pry the case apart.
    • It is easiest to start on the corners.
    I'm not sure what's wrong with ours. The color started fading and the picture looked strange. If I pressed the cubby firmly together it would work for a little while. Now I can't get that to work either. Could it just be a loose connection?
    thisnotbiznas - crwdns2934203:0crwdne2934203:0
    Check the connection for the LCD at the motherboard. Lift up the latch to release the cable, remove and reinstall the cable, and then close the latch again.
    Stephen Martinez -
    Where do I find the LCD connector? My screen is very dim but works.
    tnsimons - crwdns2934203:0crwdne2934203:0
  2. Sprout Channel Cubby Digitizer Replacement, Digitizer: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once opened, carefully peel back the black electric tape around the digitizer.
  3. Sprout Channel Cubby Digitizer Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unclasp the electrical plastic strip by gently pulling up on the white colored clasp.
  4. Sprout Channel Cubby Digitizer Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the five screws holding down the motherboard.
  5. Sprout Channel Cubby Digitizer Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once all five screws are removed, you should be able to lift up the motherboard.
    I leave the motherboard and battery in place when replacing the digitizer. You only need to unscrew the motherboard to be able to lift it up enough to access the screw that is sometimes install in the front bezel. After you remove the 4 or 5 screws from the bezel, you can pop off the bezel and replace the digitizer with the LCD still in place. You just have to be careful to not damage the LCD while removing the digitizer.
    Stephen Martinez - crwdns2934203:0crwdne2934203:0
  6. Sprout Channel Cubby Digitizer Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four remaining screws.
    • This can be done with the battery still attached but is easier if it is unattached.
  7. Sprout Channel Cubby Digitizer Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the metal sheet covering the screen and digitizer.
    • Removing the screen is a very fragile process and needs to be done slowly. The nylon spudger is the best tool for this.
  8. Sprout Channel Cubby Digitizer Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sprout Channel Cubby Digitizer Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove all of the white pegs located along the perimeter of the plastic. You'll need to remove all of the pegs to remove the white front face.
  9. Sprout Channel Cubby Digitizer Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sprout Channel Cubby Digitizer Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • To take out the digitizer, remove the connector ribbon from the plastic and then slowly apply pressure to the corner and edges of the digitizer.
crwdns2935229:05crwdne2935229:0
David Meyers
crwdns2935283:008/26/15crwdne2935283:0
244 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 14-101, Meier Fall 2015 crwdns2935289:0USF Tampa, Team 14-101, Meier Fall 2015crwdne2935289:0
USFT-MEIER-F15S14G101
Ok I opened up the back and I accidentally pressed a little on the battery and now my screen is all white no picture. What did I do is there a way to fix the picture?
deysi gallegos - crwdns2934203:0crwdne2934203:0
Most likely the LCD is broken and needs to be replaced.
Stephen Martinez -
You don't need to remove the mother board or the battery from the LCD to replace the digitizer. Once you remove the screws from the motherboard you can lift it up to access the screw for the front bezel and access the bezel clips underneath. Taking the battery off the LCD will most likely damage the LCD, so don't even mess with it. After you have the front bezel removed, flip the entire assembly over and you can replace the digitizer. Make sure you remove all the black foam and adhesive from the case after the digitizer is removed. This makes assembly easier and prevents damage to the new digitizer.
I replaced my digitizer screen and it is still not working, what is the screen under the first screen called and it is still showing a dysfunctional screen
pam - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 3
crwdns2942667:0crwdne2942667:0 3,828
