Sprout Channel Cubby Battery Replacement
  1. Sprout Channel Cubby Battery Replacement, Dissasemble the device: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sprout Channel Cubby Battery Replacement, Dissasemble the device: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use an opening tool to push in and release sixteen small plastic clips around the edge of the case. As the clips are released, gradually pry the case apart.
    • It is easiest to start on the corners.
    I'm not sure what's wrong with ours. The color started fading and the picture looked strange. If I pressed the cubby firmly together it would work for a little while. Now I can't get that to work either. Could it just be a loose connection?
    thisnotbiznas - crwdns2934203:0crwdne2934203:0
    Check the connection for the LCD at the motherboard. Lift up the latch to release the cable, remove and reinstall the cable, and then close the latch again.
    Stephen Martinez -
    Where do I find the LCD connector? My screen is very dim but works.
    tnsimons - crwdns2934203:0crwdne2934203:0
  2. Sprout Channel Cubby Battery Replacement, Battery: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sprout Channel Cubby Battery Replacement, Battery: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the black electrical tape over the ribbon connector.
    • Remove the ribbon connector over the battery.
    • Make sure to be careful of the ribbon connector while working on the device.
  3. Sprout Channel Cubby Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Next you must heat up the battery to help weaken the adhesive connecting the battery to the device.
  4. Sprout Channel Cubby Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once this is done start to pry the battery away from the device carefully. It helps to start at the corners and move inward.
  5. Sprout Channel Cubby Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sprout Channel Cubby Battery Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Once you remove the battery from the device it is still connected by three wires: red, black, and, white. It is important to remember the order they are in when reconnecting the new battery.
jasen biggins
crwdns2935283:008/26/15crwdne2935283:0
741 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 14-101, Meier Fall 2015 crwdns2935289:0USF Tampa, Team 14-101, Meier Fall 2015crwdne2935289:0
USFT-MEIER-F15S14G101
crwdns2947412:07crwdne2947412:0
Ours is only 6 months old. It only works when it stays plugged in. Battery is bad?
Rachel - crwdns2934203:0crwdne2934203:0
I had the same problem, only played while plugged in and would not charge.. I found that the battery wires while appearing tight one wire had broken inside the wire insulation at the solder pad on the main board. When I redid the connection it charges, and works well. 8/11/16
larrywb135 -
My grand daughters won't come on, should I take it to an electronic store?. I don't want to try and pry it open, for fear I may make it worse, she loves her tablet, and it is very helpful for her with school, she's had it 2 years and I put it away for about 8 month, for going on line, without permission, I gave it back in Sept. Now its not charging or coming on. Thank you.Deborah
jacksondebo2010 - crwdns2934203:0crwdne2934203:0
You can get one at Amazon, EBay and more.
Liu Woods -
Help I need a new battery. Where can I get one.
crzyinind - crwdns2934203:0crwdne2934203:0
This is ridiculous as much as it cost and then for it not to work!
Cheryl - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 3,681
