Spin Master Hatchimal Draggle Speaker Replacement
  1. Spin Master Hatchimal Draggle Speaker Replacement, Plastic Wing Replacement: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • lay the Hatchimal on its side.
  2. Spin Master Hatchimal Draggle Speaker Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the plastic opening tool, push in on the purple clip.
  3. Spin Master Hatchimal Draggle Speaker Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the wing off of the hatchimal.
    • The wing should come off with little resistance.
  4. Spin Master Hatchimal Draggle Speaker Replacement, Fur Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Spin Master Hatchimal Draggle Speaker Replacement, Fur Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Cut the fur retaining zip-tie with a pair of scissors.
  5. Spin Master Hatchimal Draggle Speaker Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Spin Master Hatchimal Draggle Speaker Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the fur up until it can't go further.
  6. Spin Master Hatchimal Draggle Speaker Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Spin Master Hatchimal Draggle Speaker Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Spin Master Hatchimal Draggle Speaker Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the spudger tool to push up on the black clip to free it.
    • Pull the clip out.
  7. Spin Master Hatchimal Draggle Speaker Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Spin Master Hatchimal Draggle Speaker Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Spin Master Hatchimal Draggle Speaker Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift fur up to reveal the next set of clips.
    • Insert a spudger to push up on the black clip to free it.
    • Pull out the clip.
  8. Spin Master Hatchimal Draggle Speaker Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Spin Master Hatchimal Draggle Speaker Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the fur up and over the Hatchimals Head.
    • Remove the six 12mm Phillips #00 screws from then body.
  9. Spin Master Hatchimal Draggle Speaker Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Spin Master Hatchimal Draggle Speaker Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the casing apart.
    • Remove the yellow speaker cable.
  10. Spin Master Hatchimal Draggle Speaker Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Spin Master Hatchimal Draggle Speaker Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Spin Master Hatchimal Draggle Speaker Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the three 7mm Phillips #00 screws from the head.
    • Remove the wheel base and the circuit board carefully not to damage the spring.
  11. Spin Master Hatchimal Draggle Speaker Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Spin Master Hatchimal Draggle Speaker Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Push the six black fur clips out using the spudger.
    • Remove the fur completely.
  12. Spin Master Hatchimal Draggle Speaker Replacement, Speaker Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently pull the yellow speaker cord from circuit board. There will be little resistance.
  13. Spin Master Hatchimal Draggle Speaker Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Spin Master Hatchimal Draggle Speaker Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two 7mm Philips #00 screws from the head.
  14. Spin Master Hatchimal Draggle Speaker Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Spin Master Hatchimal Draggle Speaker Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the speaker cover off.
    • Remove the speaker.
Hector Lopez
crwdns2935283:002/14/18crwdne2935283:0
269 crwdns2915208:0crwdne2915208:0
USF Tampa, Team S1-G5, Nance Spring 2018 crwdns2935289:0USF Tampa, Team S1-G5, Nance Spring 2018crwdne2935289:0
USFT-NANCE-S18S1G5
Where can I get a new speaker?
Jeff - crwdns2934203:0crwdne2934203:0
Same question . Where to get a matching speaker. Ebay is full of similar 23mm speakers. But which one to get? My Hatchimal speaker says 25w. I find it hard to believe it is 25 watts. The ones on ebay are 1 watt, 2 watt or half watt.
kewrock - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 1,900
