Spin Master Boxer Wheel Gears Replacement
crwdns2942287:0crwdne2942287:0If Robot fails to move, the gears inside of wheels may need to be replaced. Follow this guide for instructions on how to access and replace gears. This can be applied to both sets of wheels. You will need a Phillips #00 Screwdriver and tweezers.
Set Spin Master Boxer on your workspace so that the bottom panel faces upwards.
Using a Phillips #00 screw driver, unscrew the four 4mm screws in each corner of the bottom panel.
Carefully remove the bottom panel of the Spin Master Boxer by lifting up, away from the main body of robot.
While holding onto the axels of the wheels, gently pull the top panel of the robot away from its body.
Remove the plastic screen from the body of the robot. It should come off easily as it is not attached by anything.
Place robot on back so that the sensors are facing up.
Gently separate the left set of wheels from the inner portion of the circuit board, by gripping the wheels and pulling them away from main body of robot.
Repeat the process for the right set of wheels.
I just want to know the type of the black transistor in the black wheel.
Thanks.
Use the Phillips #00 Screwdriver to remove the 3mm screw that connect the black wheels to the gears.
Grip wheel, and gently pull up, to separate white gear casing into its front and back panel.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Using tweezers, grip defective gear, and pull up and out of gear system to replace.
my problem is the motor it wont respond, where can i buy same motor what size.?
en donde puedo conseguir los engranes soy de cdmx
crwdns2947821:0crwdne2947821:0
crwdns2947823:0crwdne2947823:0crwdns2947412:03crwdne2947412:0
This is super useful guide and picture are clear for the steps. Will be excellent to know where to buy these gears replacements?
Hello. Thé motor seems to be broken. Do you Knowles ils spec to buy à New one.
Sorry, im french...
Tanks.
Do you know its spec to buy a new one?
Realy sorry...
think you i can fix
Darren Davis - crwdns2934203:0crwdne2934203:0
