Spin Master Boxer Remote Trigger Buttons Replacement
    1. Spin Master Boxer Remote Trigger Buttons Replacement, Remote Trigger Buttons: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Lay the remote flat on your work space, with joysticks facing you.
    2. Spin Master Boxer Remote Trigger Buttons Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove both joysticks by gripping under circular knob and gently pulling towards you.
      • The joysticks should detach without much effort.
    3. Spin Master Boxer Remote Trigger Buttons Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use the Phillips #00 Screwdriver to remove 4mm screw on the center battery panel.
      • Remove the batteries from the remote and set it to side.
      • Use the same screwdriver to remove all four 4mm screws on back panel.
    4. Spin Master Boxer Remote Trigger Buttons Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Spin Master Boxer Remote Trigger Buttons Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Insert the Jimmy in between the top panel and the bottom panel.
      • Gently use the Jimmy to separate both plastic panels from each other.
      • Pull the panels apart and set bottom piece on workbench.
    5. Spin Master Boxer Remote Trigger Buttons Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Spin Master Boxer Remote Trigger Buttons Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Pinch the trigger between index finger and thumb, and lift up, away from circuit board.
      • Inspect the square button attached to circuit board to ensure functionality. If there is an issue with connection, a new circuit boards may be required.
Lauren Roide
crwdns2935283:004/16/19crwdne2935283:0
769 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S1-G1, Maness Spring 2019 crwdns2935289:0Cal Poly, Team S1-G1, Maness Spring 2019crwdne2935289:0
CPSU-MANESS-S19S1G1
crwdns2936753:030crwdne2936753:0 48
crwdns2942667:0crwdne2942667:0 1,334
