Sphero R2-D2 Battery Replacement
  1. Sphero R2-D2 Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sphero R2-D2 Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sphero R2-D2 Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    Jimmy
    $7.95
    • Start by removing the bottom ring. If the droid can still be turned on, open the Sphero app to connect and turn it on to extend its central and side legs, then remove the bottom ring.
    • Otherwise, you'll have to first remove the side legs. Use a Jimmy to pop up the covers of the arms and remove the 3 screws holding the arms. Slowly remove the arms and then the bottom ring.
    • Turn off the droid to return the central and side legs to their original positions.
  2. Sphero R2-D2 Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sphero R2-D2 Battery Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    Jimmy
    $7.95
    • Use a Jimmy or another prying tool to remove the two vertical back panels. Remove the screws holding the back of the droid.
    • Slowly work your way to separate the back of the droid from the front. Now you should have access to the internal components.
  3. Sphero R2-D2 Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sphero R2-D2 Battery Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sphero R2-D2 Battery Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Carefully unplug and remove the original battery from the slot. The original battery connector is proprietary and needs to be spliced into the new battery. Cut the connectors from both batteries. Splice the original battery connector with the replacement battery.
    • Insert the new replacement battery into the slot.
    • Plug in the battery connector.
  4. Sphero R2-D2 Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Before closing it, plug in a micro USB cable to make sure the droid is charging the new battery.
To reassemble the droid, follow the instructions in reverse order.
JP Legat
crwdns2935283:009/04/18crwdne2935283:0
188 crwdns2915208:0crwdne2915208:0
Hey there, thanks for all the info here! One question, what type/size wire connectors did you use to splice the old wires to the new battery?
Rsquared1179 - crwdns2934203:0crwdne2934203:0
Hi! Both battery wires are the same. You just have to cut the wires - keeping the original propriety connector - of the original battery and solder the wires to the replacement battery wires - which, of course, you also have to cut the wires to remove the connector that comes with it. You can use heat shrinking tubing after soldering the wires. I hope it helps!
JP Legat - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 21
crwdns2936753:030crwdne2936753:0 76
crwdns2942667:0crwdne2942667:0 1,359
