Sphero Ollie Battery Replacement
  1. Sphero Ollie Battery Replacement, Tires and Hubcaps: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Firmly grasp Ollie in one hand.
    • Remove the blue rubber tire in a peeling motion with your opposite hand.
  2. Sphero Ollie Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sphero Ollie Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Continue to firmly hold Ollie in one hand.
    • Use a Plastic Opening Tool to gently pry off the hubcap.
    • Avoid inserting the Plastic Opening Tool into the empty holes, but instead use the tool near the tabs holding the hubcap in.
    • Do not aim the hubcap towards another person as it may pop off with force.
  3. Sphero Ollie Battery Replacement, Motherboard: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Loosen and remove the 10mm screw on each side of the device using a JIS 1 screwdriver tip.
    • Remove the plastic tire frame from the device
  4. Sphero Ollie Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sphero Ollie Battery Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Loosen and remove the four 10mm Screws on the underside of the device using a JIS 1 tip.
    • Firmly grasp the bottom of the device and pull the top half of the outer case off of the bottom.
  5. Sphero Ollie Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sphero Ollie Battery Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Loosen and remove the 10mm screws holding the blue tooth connector as well as the two 1 10 screws holding the motherboard to the case using the JIS #1 screwdriver
    • Loosen and remove the 10mm screws holding the antenna to the case.
    • Gently remove mother board from the case with an upward motion.
  6. Sphero Ollie Battery Replacement, Battery: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sphero Ollie Battery Replacement, Battery: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sphero Ollie Battery Replacement, Battery: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • After you have removed the motherboard, use a JIS #1 screwdriver to remove the four 10mm Screws holding in the cog shields.
    • Next, you want to pull apart the clips (two on each side) holding the top piece of the shield to the frame.
    • Then, once you have freed the cogs, you can lift the cog and remove it from the frame.
    • To completely remove the cog shield out of the way, carefully remove the black pin connectors from the slot in the shield.
  7. Sphero Ollie Battery Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sphero Ollie Battery Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Once you have removed the cog out of the way, you can then pinch the clip to access the battery.
    • To remove the battery, simply pull on it with slight force as it is held tight by adhesives.
    Where can I find a new battery I can’t find one anywhere
    Brayden Tervort - crwdns2934203:0crwdne2934203:0
    Try checking the specs of the current battery and find one that can at least fit into the robot then attach the original connector.
    Alexander Montalvo - crwdns2934203:0crwdne2934203:0
    Szia!
    Nagyon, nagyon kiválló amit közreadtál! Tisztelettel köszönöm Szilárd
    Halenkár Szilárd - crwdns2934203:0crwdne2934203:0
crwdns2935229:013crwdne2935229:0
Krystal Hedrick
crwdns2935283:010/30/17crwdne2935283:0
382 crwdns2915208:0crwdne2915208:0
UW Tacoma, Team S1-G3, Rose Fall 2017 crwdns2935289:0UW Tacoma, Team S1-G3, Rose Fall 2017crwdne2935289:0
UWT-ROSE-F17S1G3
crwdns2947412:07crwdne2947412:0
How do you buy a new battery, where do you get them from?
Alex - crwdns2934203:0crwdne2934203:0
Alex,
Amazon (Uxcell Power Supply DC 3.7 V 1000 MAh 803040 Li-ion rechargeable lithium Polymer Li- Po Battery
Keith Johnson -
Yes I need to find a battery as well
Keith Johnson - crwdns2934203:0crwdne2934203:0
Need a battery email me terrys2207@yahoo.co.uk
Terry Saunders - crwdns2934203:0crwdne2934203:0
Can I get a motherboard replaced in ollie. Please help me with reply to my email sgandham1980@icloud.com
gandham santhosh - crwdns2934203:0crwdne2934203:0
I need a battery email me at simonlalonde2006@gmail.com
Simon Lalonde - crwdns2934203:0crwdne2934203:0
The instruction is flawless. My battery had the code 803450 (3.7V 1000mAh). On the internet, the standard is now a battery with this designation but 1500mAh, so it's even better, the only difference is that the new ones have 3 wires, the extra white one is for the thermistor, overheating protection, you don't have to use it. If you are stubborn, you can even use the original plug of the new battery, even though it has 3 pins, by slightly opening the ones on the motherboard, you can easily put this plug on, you may only need to widen the hole after the old plug, if you do not want to destroy the plastic inside to fit the new plug , then you will have to cut off the plug from the old battery and solder it to the new one. Everything works as it should after replacement.
dimmiu - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 25
crwdns2936753:030crwdne2936753:0 74
crwdns2942667:0crwdne2942667:0 8,684
