This guide will walk you through the process of replacing dead speakers on the iHome iP37.
crwdns2935267:0crwdne2935267:0iOpener$24.95
Pry the exterior housing off the iHome iP37. You may need extra leverage to do this.
Remove these eight 9 mm screws using a Phillips #2 driver.
Carefully lift the cover off. It may be a little sticky from glue.
Remove the four 6mm screws that hold the broken speaker in place. This step requires a Phillips #1 driver. If you are replacing both speakers, remove all 8 screws.
Hold the speaker by its cylindrical frame and cautiously lift it away from the rest of the device.
De-solder the existing soldered connections and remove the speaker from the rest of the device.
Insert and solder in a working speaker of the same model. Make sure the points where the wire ends connected are consistent with the old speakers.
Good afternoom, my name is vladimir and i ‘m interested both speakers, where i could fi nd them to replace in my ihome? Could you help me?
Vladinir reyes - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
