If the ear cups on your Q10 have worn out, you can replace them quite easily.
Use included spudger to pry around the edges
Work your way around popping each of the 6 clips that hold the ear cup down
Align the pin on the cup with the divit on the earphones
Press gently together until all clips click into place
Use the same technique to remove the second ear cup
Follow the same steps on the other side
Congratulations you have replaced the ear pads on your headphones. Enjoy your music!
