SoundBot SB571 Battery Replacement
  1. SoundBot SB571 Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Before disassembling the speaker, make sure it is powered off.
    • Place the speaker on a flat surface.
    • Take your blue plastic opening tool and remove the outside cover.
  2. SoundBot SB571 Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Reorient the speaker so the black panel is facing up.
    • Remove the 4, 0.9 cm screws from the back panel using a Phillips PH1 screwdriver.
    • Now remove the plate.
  3. SoundBot SB571 Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Reorient the speaker so the bottom is facing up.
    • Remove the 4, 0.9cm screws from the bottom using a Phillips PH0 screw driver.
    • Now open the plate.
  4. SoundBot SB571 Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 SoundBot SB571 Battery Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • With the bottom plate removed now use the blue plastic opening tool to lift up the circuit board from the device.
  5. SoundBot SB571 Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 SoundBot SB571 Battery Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the battery wires from the circuit board.
  6. SoundBot SB571 Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 SoundBot SB571 Battery Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 SoundBot SB571 Battery Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Reorient the speaker so the back side is facing up.
    • Now that the battery wires have been disconnected, use a blue plastic tool to release the battery from the adhesive strip.
    • Loop the battery wires through the opening in the back plate.
    • The battery and it's connective wires have been completely removed from the speaker.
crwdns2935229:012crwdne2935229:0
Yana
crwdns2935283:002/09/16crwdne2935283:0
672 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 2-50, Cagle Spring 2016 crwdns2935289:0USF Tampa, Team 2-50, Cagle Spring 2016crwdne2935289:0
USFT-CAGLE-S16S2G50
crwdns2947412:09crwdne2947412:0
Please provide the source to buy the replacement battery
Madhu Mohan Bhukya - crwdns2934203:0crwdne2934203:0
Sir ,m n jully m flipcart se soundbot buy tha jisme kuch dikat aa rhi h bettery ki bajah se
Raj Saini - crwdns2934203:0crwdne2934203:0
It says above that battery not for sale.
international.loop - crwdns2934203:0crwdne2934203:0
A simple online search and you will find the battery.
Mark Friend - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 9,264
