Sostituzione disco rigido iPod Classic
  1. Sostituzione disco rigido iPod Classic, Disco rigido: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Apple ha progettato i nuovi iPod per essere molto difficili da separare senza distruggere le parti principali. A causa del frontale metallico e della cover posteriore pure in metallo e dei 13 (sì, 13) gancetti in metallo che tengono il tutto insieme, questo è uno degli iPod più difficili da smontare.
    • Procedi con attenzione e l'avvertimento che potresti danneggiare il tuo iPod ben oltre le sue condizioni attuali. Inoltre ti potrebbero servire più strumenti per l'apertura in plastica, in quanto si possono rompere facilmente aprendo l'iPod. Divertiti!
    • Prima di aprire il tuo iPod, assicurati che l'interruttore hold sia nella posizione bloccata.
    If you're meticulous, the job can perfectly be done, without any of the recommended tools. I hadn't the time to order them, so I opened my iPod with the large blade of my Victorinox swiss army knife. By just following the instruction I succeeded in releasing all of the metal tabs all around the iPod, and didn't damage any of them. You can clearly hear them "declipsing". I think the blade of the Victorinox is thiner than the putty knife, the only thing you have to take care of, is not to cut the black or silver painting of the front of the case, but if you are used to cut with a knife, you should succeed. Just be aware that it is however a difficult job !
    jcfsystems - crwdns2934203:0crwdne2934203:0
    Thank you for these instructions - my dead iPod classic (that died whilst attached to an ipod dock during a heavy thunderstorm which took out the dock too) is now working again. Opening the case took me 40 minutes and 7 plastic case openers not to mention very sore hands but the rest of the process worked fine. thanks again
    Stuart Hutchesson - crwdns2934203:0crwdne2934203:0
    Opened it up with MANY super thin nylon guitar picks in less than a minute starting from the two tabs on the bottom - I used the putty knife in my shop for wood filler and patching walls :)
    cmguitar - crwdns2934203:0crwdne2934203:0
    Appreciated the earlier comment about using guitar picks. It is waaaaaay easier to open the iPod with guitar picks. It still requires patience sometimes, but no noticeable damage to the iPod. Went to the local music store, they stocked Fender picks. Fender "Thin" work best for me for starters, but sometimes Fender "Medium" are needed. (Go to your local music store-- very cheap!) I have opened (and repaired successfully!) four different iPods just using guitar picks.
    Novice iPod Repair Guy - crwdns2934203:0crwdne2934203:0
  2. Sostituzione disco rigido iPod Classic: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Aprire l'iPod è complicato. Non scoraggiarti se ti serve più di un tentativo per riuscirci. Una cosa da valutare bene è l'angolo da dare all'estremità dello strumento di apertura mentre infili l'attrezzo nell'iPod. Idealmente l'angolo dovrebbe essere il più verticale possibile pur andando comunque oltre il bordo del pannello posteriore.
    • Infila uno strumento di apertura in plastica nella giunzione tra il fronte e il retro dell'iPod.
    I have with luck (several times) used the metal spudger to create a small initial gap.
    But be careful, it's easy to severely scratch the iPod.
    rousp - crwdns2934203:0crwdne2934203:0
    right here, you should insert a picture of the little clips on the rails inside the back of the ipod, so that we can visualise what we're trying to undo, & get a better idea of which way to bend, which way NOT to bend the tools.
    duncanrmi - crwdns2934203:0crwdne2934203:0
    Good point! There is such a picture showing the location of at least four (4) clips on each side of the case here:
    https://d3nevzfk7ii3be.cloudfront.net/ig...
    in the Step 4 of the “iPod Classic Teardown”: iPod Classic Teardown
    As mentioned below by Kevin M there are 3 more (1 on top and 2 on the bottom sides).
    LDS -
    Actually it’s a wayyyyyyy easier using the iFlash opening tool and following the pdf of this guy (youtube link)
    Bastien Arata - crwdns2934203:0crwdne2934203:0
    Actually it’s wayyyyyy easier using this tool as mentioned by this awesome guy on his video.
    That video is excellent. He has a PDF you print which is the same size as the iPod so you know exactly where the 11 clips are (1 on top, 2 on bottom, and 4 more along each side).
    Kevin Moorman - crwdns2934203:0crwdne2934203:0
    Appreciated the earlier comment about using guitar picks. It is very easy to open the iPod with guitar picks. It still requires patience sometimes, but no noticeable damage to the iPod. Went to the local music store, they stocked Fender picks. Fender "Thin" work best for me for starters, but sometimes Fender "Medium" are needed. (Go to your local music store-- very cheap!) I have opened (and repaired successfully!) four different iPods just using guitar picks.
  3. Sostituzione disco rigido iPod Classic: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Infila un altro strumento di apertura nella giunzione tra il fronte e il retro dell'iPod, lasciando circa 4 cm tra i due strumenti.
  4. Sostituzione disco rigido iPod Classic: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Infila attentamente una spatola metallica per circa 3 mm nella fessura tra i due strumenti di apertura, tenendola inclinata.
    • Ci sono dei binari in metallo lungo tutto il bordo interno della cover posteriore, quindi stai molto attento mentre infili la spatola.
    • Una volta che la spatola ha superato il bordo della scocca posteriore, ruotala finché è verticale e infilala attentamente (ma con decisione), facendola ondeggiare, fino in fondo all'iPod tramite la fessura creata dagli strumenti di apertura.
    I tried this on the first iPod I was trying to fix. This method really messes up the sides of the iPod. Go back and read earlier comments about using guitar picks or other tools!
  5. Sostituzione disco rigido iPod Classic: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Tieni premuta con le dita la cover posteriore dietro la spatola per minimizzare la piegatura. Lentamente piega la spatola come mostrato nell'immagine per assicurarti che la maggior parte dei ganci in metallo su questo lato dell'iPod siano rilasciati.
    • La teoria di questo metodo non è evitare del tutto di piegare la scocca posteriore, ma piuttosto di piegarla in modo controllato e facile da risistemare. Quindi ogni azione ai lati della cover posteriore deve solo allargare il bordo rispetto all'iPod e non si deve agire sulla superfice curva. Questo metodo libera la maggior parte delle clip.
  6. Sostituzione disco rigido iPod Classic: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Rimuovi la spatola dall'iPod e reinfilala più vicino agli angoli, usando la stessa tecnica di prima.
    • Se possibile, non piegare gli angoli della scocca posteriore.
  7. Sostituzione disco rigido iPod Classic: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Infila uno strumento di apertura in plastica vicino alla presa jack nella giunzione tra il fronte e il retro dell'iPod.
    • Può tornarti utile piegare la spatola per allargare la fessura per lo strumento di apertura, ma assicurati di non piegare l'angolo della scocca posteriore!
  8. Sostituzione disco rigido iPod Classic: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Infila uno spudger in metallo vicino al centro dello schermo nella fessura creata dallo strumento di apertura in plastica.
    • È facile creare una gobba difficile da sistemare in questo punto. Mentre liberi il gancio, cerca di usare lo spudger metallico facendo leva sul bordo del panello posteriore invece di piegare verso l'esterno la cover stessa.
    • Usa lo spudger in metallo per liberare l'unico gancio nella parte superiore dell'iPod.
  9. Sostituzione disco rigido iPod Classic: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Infila uno strumento di apertura in plastica vicino all'altro angolo superiore nella fessura tra il fronte e il retro dell'iPod.
  10. Sostituzione disco rigido iPod Classic: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Dalla parte opposta, infila uno strumento di apertura in plastica nella giunzione tra il fronte e il retro dell'iPod.
    • Potresti trovare più semplice inclinare lo strumento incastrato nell'angolo superiore per creare una fessura sufficientemente ampia.
  11. Sostituzione disco rigido iPod Classic: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Rimuovi lo strumento di apertura dall'angolo superiore e infilalo nella fessura tra il fronte e il retro dell'iPod, lasciando circa 4 cm tra i due strumenti (come fatto sull'altro lato).
  12. Sostituzione disco rigido iPod Classic: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Ricordiamo che ci sono dei binari in metallo lungo tutto il bordo interno della scocca posteriore, quindi stai molto attento mentre infili la spatola.
    • Tieni premuta con le dita la cover posteriore dietro la spatola per minimizzare la piegatura. Sempre lentamente piega la spatola come mostrato nell'immagine per assicurarti che la maggior parte dei ganci in metallo su questo lato dell'iPod siano rilasciati.
  13. Sostituzione disco rigido iPod Classic: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Le clip metalliche vicino agli angoli sono tristemente note per la loro tenacità nell'agganciare il pannello anteriore. È necessario liberarle per poter aprire l'iPod.
    • Infila attentamente uno spudger in metallo nella zona vicina al gancio ostinato.
  14. Sostituzione disco rigido iPod Classic: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Spingi delicatamente, facendolo oscillare, lo spudger verso il basso finché non raggiunge il fondo del pannello posteriore.
  15. Sostituzione disco rigido iPod Classic: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Inizia a liberare delicatamente la clip dal pannello anteriore.
  16. Sostituzione disco rigido iPod Classic: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Continua a far leva sulla scocca anteriore con lo spudger metallico finché la clip metallica non viene rilasciata.
  17. Sostituzione disco rigido iPod Classic: crwdns2935265:017crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Ci sono due cavi a nastro che collegano la scocca posteriore al resto dell'iPod. Nel prossimo passaggio, stai attento a non danneggiarli.
    • Prendi con una mano il pannello anteriore e con l'altra quello posteriore.
    • Fai un profondo respiro!
    • Delicatamente (DELICATAMENTE) libera i ganci restanti sulla scocca posteriore separando la parte anteriore da quella posteriore (considera il bordo inferiore dell'iPod come una cerniera), prestando molta attenzione a non danneggiare i cavi a nastro che collegano le due metà.
  18. Sostituzione disco rigido iPod Classic: crwdns2935265:018crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Usa uno spudger per far scorrere verso l'alto il fermo del connettore che fissa il cavo a nastro arancione della batteria. Devi sollevare il fermo di soli 2 mm per liberare il cavo.
    • Sfila il cavo a nastro arancione della batteria dalla sua presa.
    If the small battery black/white connector pumps out of the ipod when you are trying to unplug the cable...REMEMBER the "U" black shape is meant to be just in the same direction as the blue plastic "U" beside it. If you plug it back in the wrong way it will display "Charging please wait..." forever!.
    riverate - crwdns2934203:0crwdne2934203:0
    How did you get the black battery piece to stay in after it popped out?
    Katrina Frantz -
    I knocked this little bit out too! Any tips to get it back in? Soldering?
    David Ewing -
    This step is what ultimately destroyed my iPod. A caution to be very careful would be good.
    I got the whole black white thing disconnected from the pins. After a lot of struggle I was able to get it back in, but I couldn’t get the black locking part to go up on its own. after many tries and some tries to get it in when the black thing is closed, i tore out the pins that were connected to the panel. can’t get it back on so it isn’t connected to the battery…
    Now i have a perfect iPod with a new harddrive but I can’t use it.
    Please add a red caution sentence because I’m pretty sure that if i had known what I had to do I would’ve been more careful and I would now have a functioning iPod.
    Nonetheless, great guide! without this I wouldn’t even have tried and the harddisk came from another broken down iPod classic so it’s not that I lost money.
    stef.kuypers - crwdns2934203:0crwdne2934203:0
    I got the whole battery clamp connector (black and white) all out too… So angry about it! I thought that the white part should be disconnected too, like former iPod models. Be careful, you only have to release the BLACK locking bar! One more photo with a zoom on the battery connector could have been useful… Great guide anyway :-)!
    kabalbuzard - crwdns2934203:0crwdne2934203:0
    Hello! Trying to identify the problem on my Ipod. I think I'm not qualified to open it and do the fixing. Do you know a shop or someone in Paris that would try it? Apple says they are not qualified anymore.
    Thanks in advance!
    Baudu Camille - crwdns2934203:0crwdne2934203:0
    OK, you have to be really careful with this step! If you pry too hard, the little plastic clamp that holds the cable will come up too far and break, and then you are ****ed. It only needs to be raised millimeter or two, but at first, it doesn't move at aIl, so it is easy to pry upwards too hard. I have found that using angled tweezers while VERY GENTLY prying upwards on both sides works best. But still, BE VERY CAREFUL AND GENTLE! It's also easy not to even know that it is up all the way! So every now and then try gently lifting the ribbon cable to see if it is already released.
  19. Sostituzione disco rigido iPod Classic: crwdns2935265:019crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Appoggia la scocca posteriore accando all'iPod, stando attento a non strappare il cavo arancione della presa jack.
  20. Sostituzione disco rigido iPod Classic: crwdns2935265:020crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Solleva il disco rigido con una mano in modo da accedere al cavo a nastro della presa jack sottostante.
    • Usa uno spudger per per sollevare l'aletta in plastica che tiene fermo il cavo a nastro della presa jack. L'aletta ruoterà di circa 90°, rilasciando il cavo.
    • Sfila il cavo a nastro arancione della presa jack dal suo connettore sulla scheda logica.
    • Il pannello posteriore è ora separato completamente dall'iPod.
    I broke off the plastic tab I lost it any suggestions. How could I replace the plastic tab?
    Fabio a - crwdns2934203:0crwdne2934203:0
  21. Sostituzione disco rigido iPod Classic: crwdns2935265:021crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Ora occupiamoci di sistemare i danni fatti durante la procedura di apertura dell'iPod Classic! È molto probabile che almeno uno dei ganci in metallo della cover posteriore si sia piegato verso l'alto. Tutte queste clip devono puntare verso il basso per reinstallare la scocca posteriore.
  22. Sostituzione disco rigido iPod Classic: crwdns2935265:022crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Prendi la parte piatta larga dello spudger in metallo e spingi il gancio verso il basso, stando attento a non strappare i sottili binari dalla scocca posteriore.
    • Stai attento a non danneggiare le parti della presa jack mentre sistemi i ganci!
  23. Sostituzione disco rigido iPod Classic: crwdns2935265:023crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Appoggia il pannello posteriore su un bordo sopra una superfice pulita e resistente. Attentamente, ma con decisione, premila verso il basso facendola ruotare attorno al bordo curvo, riportandola alla forma originale.
    • Potresti dover ripetere questo passaggio molte volte per raddrizzare sufficientemente i bordi. È meglio spingere i bordi leggermente più all'interno che non piegarli abbastanza, in quanto il riposizionamento della scocca anteriore riallargherà quella posteriore nella posizione corretta.
    • Ora che la scocca posteriore è di nuovo nella bellissima forma originale, puoi continuare a riparare l'iPod.
  24. Sostituzione disco rigido iPod Classic: crwdns2935265:024crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Ruota il disco rigido fuori dal telaio e appoggialo in modo che il connettore sia rivolto verso l'alto.
    • Usa uno spudger per sollevare la piccola aletta di bloccaggio che tiene fermo il cavo a nastro arancione dell'hard drive. L'aletta ruoterà di circa 90°, liberando così il cavo.
    To be clear, the plastic tab to be flipped up is the SMALL BLACK piece shown vertically in the photo above. The spudger is pointing directly to it. The tab flips TOWARDS the ribbon. While the picture is correct, this wasn’t obvious to me.
    Linda and Brian Henning - crwdns2934203:0crwdne2934203:0
    Thanks for the feedback! I will adjust the wording to clarify this.
    Arthur Shi -
  25. Sostituzione disco rigido iPod Classic: crwdns2935265:025crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Sfila il cavo a nastro arancione del disco rigido dalla sua presa.
    • Se vuoi sostituire il disco rigido nel tuo iPod e quello nuovo non ha le staffe di montaggio in gomma e l'imbottitura in schiuma, trasferisci queste parti dal disco vecchio a quello nuovo.
    This is not the connector I have in my iPod 6th generation. It's supposed to have a Samsung 160GB NEON HS161JQ with a IDE Ultra ATA/100 interface ( CE-ATA 10-pin ). Not shown here.
    Adrien Claude - crwdns2934203:0crwdne2934203:0
    Bonjour, merci pour ce tutos, toujours aussi bien fait. De nos jours il est possible de remplacer le HDD vers un disque flash avec un adaptateur et ainsi pouvoir augmenter la taille du disque, le poids et la rapidité. Le montage est simple, par contre, le type de formatage un peu compliqué (Fat, exfat, macOS) est à faire avant le montage dans l'iPod. La remise en route une fois relié à un Mac et iTunes se déroule bien. Eddy
    Edd Lapoignee - crwdns2934203:0crwdne2934203:0
Prima di richiudere la scocca, prova il dispositivo per assicurarti che tutto funzioni correttamente.
Per rimontare il dispositivo, segui le istruzioni in ordine inverso.
crwdns2935229:0336crwdne2935229:0
crwdns2934873:0crwdne2934873:0
en it
100%
crwdns2934885:0crwdne2934885:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
iRobot
crwdns2935283:009/24/09crwdne2935283:0
1 crwdns2915208:0crwdne2915208:0
crwdns2935297:0636crwdne2935297:0
crwdns2947412:051crwdne2947412:0
The instructions worked like a charm. This is not for the faint of heart and requires some modicum of skill, but I saved a buttload of money by doing it myself. You will definitely need the recommended tools.
johannesdecruce - crwdns2934203:0crwdne2934203:0
It worked like a charm... Just need to follow the instructions carefully and you can avoid to spend 200 something € to buy a new iPod!
Thanks iFixit
Fanny Millon - crwdns2934203:0crwdne2934203:0
i couldn't get the plastic opening tool in between the 2 sections. i ended up using two razor blades instead of the plastic tools and the putty knife, i was able to replace the hard drive with very little struggle and almost no cosmetic damage(not that i care what the thing looks like)
algore2016 - crwdns2934203:0crwdne2934203:0
Thanks for a highly useful guide. Slowly and methodically, using a single-bladed, razor blade, I was able to open the case, following this procedure. Patience is, indeed, a virtue, in this case.
I was able to successfully replace the hard drive and battery.
The only snag I encountered was that the headphone jack ribbon was glued to circuit board adjacent to the connector under the hard drive. (I just left this ribbon be, not wanting to risk damaging the ribbon.) It was a bit awkward straightening the case edges, but I managed.
Overall, I'd give this guide a grade of "A"....it was nearly perfect and very clear. Bravo!
rgstout - crwdns2934203:0crwdne2934203:0
Well I managed to get it apart, though it wasn't all that difficult with the right tools, but getting it back together has been a nightmare. Just saying "reverse the process" is reall not quite enough in this case. All the little pieces of shock padding keep falling off, it's almost impossible to get the two wires plugged back in as well as keeping them in place, but I got there in the end. Or so I thought . Now my ipod has no sound (except from dock output) - and on investigating I find I have severed the orange cable near the jack itself- either by bending it or catching it on something. So another part to buy. So it's a warning to be very careful.
James Skilton - crwdns2934203:0crwdne2934203:0
Yeah. I did it. It wasn't easy, and the results could have been prettier, but I did it.
On opening, I found my plastic tools to be useless. I ended up taking the blade of a cheap Gerber knife to the thing, being careful not to damage the rails. I found that thin grade guitar picks were a great thing to stick in the spaces!
It's a good idea to take a picture of the innards once you open it. The little bumpers can be a bit tricky to reposition when you put it back together. Also you'll want to remove the blue foam padding if possible from the old hard drive and stick it to the new one.
Don't freak out when you get to the ribbons. They're tougher than they look, and they seem to know where to go. I did have to use a pair of needlenose plyers to guide the headphone ribbon back into place.
If you're a stickler for aesthetics, then pay close attention to steps 21-23. Especially 23, or you'll have unsightly gaps along the edges.
The hardest part of this project is taking it apart. Take your time.
David - crwdns2934203:0crwdne2934203:0
This is great instruction.
Could you please add the list of compatible hard drives.
I have a need for larger hard drive and plan is to install 512GB SSD drive for my iPod Classic 160GB 7th Gen. Do you now is there some limitation in HD size in iPod?
The plan is to replace original 160GB hard drive with Samsung PM851 512GB SSD drive
Based on my understanding this adapter works
Mini PCI-E Msata SSD to 40pin ZIF Adapter Card
http://www.ebay.com/itm/Mini-PCI-E-Msata...
with Samsung PM851 512GB mSata Internal Solid state drive SSD
http://www.ebay.com/itm/Samsung-PM851-51...
I guess that I need also new wider back cover for iPod classic.
http://www.ebay.com/itm/upgrade-iPod-Cla...
I'm not sure how much space is needed for Msata to SSD adapter and ssd drive
Any comments?
Jari - crwdns2934203:0crwdne2934203:0
@Jari
Have you considered using a Compact Flash instead of SSD? i.e. check eBay for "CF to Zif 1.8" HDD SSD IDE Adapter"...
htk - crwdns2934203:0crwdne2934203:0
I tried to install Samsung PM851 512GB SSD drive for iPod Classic, but iPod does not detect the drive.
I formatted SSD drive to FAT32 beforehand, but finally I had to intall original 160GB drive back.
Jari -
This was indeed a tough shell to crack! The plastic tools can bend easily and become weak so be careful as you are trying to create the initial gap for the putty knife. Once you get one side unhinged, the rest moves much more quickly!
Upgraded my 80 to a 120 and did the battery while I was at it...now hopefully I can squeeze another 5 years out of my iPod which should be long enough for a Apple to release Touch with a large enough hard drive for all my music!
doomius - crwdns2934203:0crwdne2934203:0
The guide is very good. Take your time and with patience and perseverance it can be done. I used a kitchen palette knife to prise open the case. I replaced the hard drive and after several attempts at fixing the hard drive cable in place given that the flimsly retainer clip broke first time on the new drive. I used a piece of paper in the slot to keep the cable connected and secure which was then curved back and taped into place to keep the pressure on. Fiddly but sucessful. I now have my ipod up and working. Not bad for a 7 year old piece of kit which has has a few knocks and bashes on the way. So it is worth trying!
Paula Pompei - crwdns2934203:0crwdne2934203:0
Had great success using 6 guitar picks instead of the putty knife. Allowed me to move in smaller sections and caused zero damage to the iPod. Didn't even bend any metal clips mentioned in Step 21! Replacing a damaged drive with 128 GB of flash memory using StarTech 1.8-Inch ZIF to CF Adaptor and Komputerbay Dual Micro SD to CF adaptor. Can use two cheaper 64 GB SD cards to achieve a solid state 7th Gen Classic!
http://www.amazon.ca/gp/product/B001CC3N...
http://www.amazon.ca/gp/product/B004WKIG...
Sea Pea - crwdns2934203:0crwdne2934203:0
Don't know much about memory technologies but why did you use 2* micro SD cards instead of a 128gb CF card?
matt donovan -
A very useful guide -I read through a couple of times before starting. I did not have spudgers, but used a variety of other small tools. It came apart more easily than expected, and the case only needed one clip bending back. There are some minor marks at the joint between case and front, but all works fine.
Esbjorn - crwdns2934203:0crwdne2934203:0
I don´t have the plastic tools, which I believe are meant to open the device without scratching it. I still haven´t repaired my iPod Classic, but I followed the instructions to open it and identify the hard drive model so I could order a new one. I opened it with a round blade knife and two coffee spoons. :) I wasn´t afraid to scratch the dang thing as it was already badly scratched. It will be my "backup" Classic, as I already got myself a new one (one of the last ones).
Ubirata Silva - crwdns2934203:0crwdne2934203:0
Is there a drive bigger than the 160 Gb that will fit? I just need more space. :)
Orcinus Orca - crwdns2934203:0crwdne2934203:0
I have a 512gb flash memory iPod Classic. It has a Tarkan adapter in it. Paid $400 for it. Didn't do the work myself. Just paid for, basically, a new iPod.
Chris George -
I would like to try this because my iPod classic died and I'm very upset that it's been discontinued. I have no want for a Touch and I listen to too much music for a low GB. I must ask though where you got the new hard drive? Or what kind of hard drive it is. I've only ever installed a hard drive in an XBox 360 slim and that was just opening a panel and slipping it into a port. Thanks.
CyanideBreathmint - crwdns2934203:0crwdne2934203:0
Do a flash memory upgrade. Mine is at 512gb now. Replaces the hard drive with flash memory. It has no moving parts and it's lighter!!!
Chris George -
Everything went smoothly. I replaced both the drive and the battery at the same time. I suggest you invest a little $ and buy the necessary tools as I did. Makes everything sooooooo
much easier. Took about an hour but what the heck.....I wasn't doing much else. Now I have my Tunes back! Thanks iFixit.com!
Kenny From San Clemente, CA
kenwinters1 - crwdns2934203:0crwdne2934203:0
Great guide, just take your time and make sure you use the proper tools. Used this guide for my iPod and you can't tell it has been opened whereas I used a different guide in the past for the Mrs's iPod with no where near as good results.
Michael Gregory - crwdns2934203:0crwdne2934203:0
This is a great guide, I was able to change both my hard drive and my battery in a simple 30 minutes since my package arrived. My iPod always worked really hard just to stay powered on, it felt like it was going to explode every time I picked it up, now the iPod is running quietly and smoothly with no problems. And for once I am able to sync all of my music from iTunes onto it.
Patricia Princivil - crwdns2934203:0crwdne2934203:0
A few weeks back I saw someone selling a 160 gig Classic on LetGo for $35 and decided to get it. Got home and discovered why the price was so low, the disk could not be accessed when I tried a restore. So I ordered up some parts from Amazon, a ZIF to CF adapter board and a CF to SD adapter. Ran about $20 for the pair. I went to Harbor Freight Tools to see about a putty knife but decided to get a razor blade with handle that I found in the paint scraping aisle where the putty knives were. Turned out this was the only tool I needed to get the clips undone while not uglifying the iPod. I pried on the edge of the back case like the instructions show using the putty knife to do, then a very small amount of persuasion by placing a small flathead screwdriver in the gap and a bit of twisting got it apart.
Randy - crwdns2934203:0crwdne2934203:0
(cont'd) I put a 32 gig SD card in the adapter for testing, then put the adapter into the ZIF adapter and slid it in. I had a 32 gig solid state Classic to show for my efforts. I synced some music and tried playing through some headphones to see what I got, after all this was a cheapie secondhand 'Pod so had to find out if it'd work. Works great.
I see that Other World Computing has a more elegant part going straight from ZIF to SD, I think I'll try that. The slim 7th gen doesn't look like it'll hold the adapter contraption in there now. I haven't tried closing it yet since I need a bigger SD.
Thank you for the guide! It is indeed very difficult, but not impossible. I followed the directions as closely as possible. I had to use a utility knife to open it. The seam was too tight for the plastic tools. Everything else went fine. If you use extreme care and follow the directions exactly you should be able to do this with no damage to ribbon cables. I did, at times, feel like I was performing microsurgery. :-) All went well in the end and I once again have a working iPod classic - at a fraction of the cost of replacing it. Thanks again for the guide and for the great customer service when ordering the parts.
Richard Tracy - crwdns2934203:0crwdne2934203:0
The instructions were absolutely clear( even if I deduced some of the words from the context) :-) The only difficulty for me, was to put as much power on the putty knife as necessary. Too little and too shy at the beginning. ... but then you get the necessary feeling! Again it's not as difficult as it seems in the beginning. By the 25-th fixing you can open a little fixing shop :-D. Thank you iFixit!!! Thank you all enthusiasts who post here!!!
laureantudor - crwdns2934203:0crwdne2934203:0
I was able to successfully install the physical drive, however the volume is not working well-it can be heard faintly if the volume is cranked all the way up-but its all very distorted. Any suggestions?
Alexander Mathew - crwdns2934203:0crwdne2934203:0
I was able to do this with an 4" icing spatula without bending the case at all. Great guide. My classic is now 250GB of storage, faster, and lighter. Thanks!
azcodemonkey - crwdns2934203:0crwdne2934203:0
Hi I have 2 questions.
1) I accidentally broke the (brown) connector holding the battery cable to the logic board. What is it called and how can I get a replacement?
2) I exchanged the LCD Color display between 2 ipod classic (one and A1238 80GB with broken screen and the other A1238 160GB perfect screen) the result was a blank whote screen but if i switched it back to the broken screen, I could see the apple logo n startup. How can i solve this problem? Should i buy a new LCD Color display? Are there any difference between the parts?
Please help....
epatmos - crwdns2934203:0crwdne2934203:0
Just replaced my bad hard drive, so far so good. This site was a lifesaver
john maibauer - crwdns2934203:0crwdne2934203:0
Great instruction, had two iPods- one with screwed battery, the other one with damaged hard drive: Made one out of two- was easy even though i didn't had the plastic tools, a hair clip is perfect for this job! the iPod is dead, long live the iPod
Bep Straßenkehrer - crwdns2934203:0crwdne2934203:0
I have saved a lots of valuable photos in my iPod classic. I dropped it one time and it is not working now.It can’t turn on, can’t link to itunes .If I replaced the hard drive and battery,I can still find my photos back? Anyone who can help me please send me an E-mail.dylanweicn@icloud.com Thank you in advanced .
ducwei2001 - crwdns2934203:0crwdne2934203:0
So I’ve been using my iPod classic as an external drive, and I dropped it and now my computer won’t recognize it, and won’t even come on; I really don’t care about the iPod but the contents how can I test the Hard drive to see if I can get the documents off of it? Any ideas :(
Abe Montes - crwdns2934203:0crwdne2934203:0
The instructions were perfect. I did use a few different tools for my own preference but anyone can improvise a little on this project. Had no issues. You have to go slow and be methodical. This is not an easy tear-down but not nearly as difficult as you might think. Of course hand/finger size may come into play. I was successful on my first attempt. You not only need to be mechanically inclined but have some knowledge of electronic assembly, in general. Not for the inexperienced unless you learn quickly.
Kelly - crwdns2934203:0crwdne2934203:0
This guide worked very well for me. I found a jewelers loupe to be indispensable and recommend one highly.
Is it possible to install a HD from a 160GB Ipod to a 120GB Ipod Classic? Will the device read 160Gb normally?
carlosedgi - crwdns2934203:0crwdne2934203:0
This site is super handy for that:
https://www.iflash.xyz/store/iflash-comp...
Looks like that ipod gets capped at 128gb but the HD would still work I think.
Alec McWilliam -
The opening method works great with other i Pods too.
Daniel Zwerver - crwdns2934203:0crwdne2934203:0
I can't wait to attempt this. I either have a fix iPod or it remains the same just in many pieces.
Jose Godoi - crwdns2934203:0crwdne2934203:0
I need to have the hard drive replaced, but I have the worst luck doing things like this. Maybe I should pay someone who’s more nimble to do it for me.
elvimark01 - crwdns2934203:0crwdne2934203:0
Hello,
I am looking to upgrade my classic 5ht gen ipod. where in toronto can i find techs and or services.
hugablepercy@gmail.com
purcell greene - crwdns2934203:0crwdne2934203:0
Gracias por las guías y a quienes las traducen al español.
Son de gran ayuda¡¡
Miguel Pestruchi - crwdns2934203:0crwdne2934203:0
How do you load a new hd with operating software? I have an MP102, Ipod. Help
pookyman69 - crwdns2934203:0crwdne2934203:0
The instructions were amazing- I did improvise & used a metal clip to disassemble the iPod completely in 1/2 an hour without breaking any thing or bending the clips. I was lucky-the case was already slightly separated at one corner from being dropped…
Ronni Marcinkowey - crwdns2934203:0crwdne2934203:0
Where today can I buy a hard drive replacement for my iPod classic 80gb
Stacey David - crwdns2934203:0crwdne2934203:0
Hopefully will get round to replacing the knackered HD on my iPod soon. These instructions will no doubt help, will report back.
Carpark 2 - crwdns2934203:0crwdne2934203:0
Any ideas for how to repurpose/ upcycle these hard drives into something else? Maybe a mini NAS to stream music around my house? Doesn't seem like there's many DIY ideas on the interwebz for what to do with these things but I think it'd be a shame to throw away tech that still has life in it!
Lotus Flower - crwdns2934203:0crwdne2934203:0
And if you wanted to transfer your music from your older drive, this is exactly what you need: ZIF HDD caddy: https://amzn.to/42furqD
pmarlow78 - crwdns2934203:0crwdne2934203:0
I found these instructions incredibly easy. Being an 11 year old, I don't really have access to plyers and vices, but I used a steak knife and I could easily take of the cover and access the insides. I did this just for fun and no intention fixing it.
Cormac Stumpf - crwdns2934203:0crwdne2934203:0
Salut à tous,
Sur mon iPod Classic le disque dur viens de me lâcher et j’ai dû d’éclipse la coque pour accéder à l’intérieur et finalement j’ai pas trouvé ça difficile, heureusement qu’avec les photos on voit bien qu’il y a 13 clips ( important ! )
j’ai remplacer le disque dur par une carte ´ iflash Solo ´( plusieurs carte sont disponible ) par une carte SD ce qui me permet d’insérer une carte sdxc où micro sdxc ( important la référence SDXC ) cette référence permet un stockage de 32 go à 1000 go.
Maximum: 4 micro SDXC de 512 go, voir 4 micro SDXC de 1000 go micro SDXC. Personnellement je vais mettre une de 512 go.
J’ai deux site interessant:
Iflash.xyz et idemigods.com, se sont des sites canadiens, rapport prix-qualités très bon… site protégé ( pas de piratage, payer quand même par paypal… sais jamais ! ) soyez patient en attendant la commande, j’ai attendue 1 mois pour le recevoir ( aucun suivie par mail ) faut attendre ( casse pied ) j’ai payer la douane 2€ en plus.
Bonne chance.
Nicolas m - crwdns2934203:0crwdne2934203:0
PERFECT!! Not a step missed not a step too many!
Chris Knight - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 83
crwdns2936753:07crwdne2936753:0 457
crwdns2936753:030crwdne2936753:0 1,839
crwdns2942667:0crwdne2942667:0 833,944
